Old 12-24-2006, 10:39 AM   #1
tas-motorsports
Difference Between 2x4 and 4x4 Frames-
Hi Guys-
We were just wondering if anyone knew of any differences between a two wheel drive frame and a four wheel drive frame from 73-87? Can a two wheel drive frame be converted over to a four wheel dirve?
By the way, Great Site!
Mathew
tas-motorsports is offline   Reply With Quote
Old 12-24-2006, 06:45 PM   #2
toomanytoyz
Luv the Crewcabs
toomanytoyz's Avatar
Thumbs up Re: Difference Between 2x4 and 4x4 Frames-
Sorry don't have the answer to your ?, Just wanted to Welcome you to site..........
Im just up the road from you in Andrews.............
Merry Christmas, Rick
toomanytoyz is offline   Reply With Quote
Old 12-24-2006, 06:59 PM   #3
1969k10stepside
One can be converted to a 4x4 but you just about need another 4x4 for the parts and you could just use that frame.Easiest to just look for a cheap 4x4 chassis and put the body off your truck on it.
Welcome to the site btw
1969k10stepside is offline   Reply With Quote
Old 12-24-2006, 07:00 PM   #4
tas-motorsports
Merry Christmas Rick, Along with Everyone Else Here!
Old 12-24-2006, 07:02 PM   #5
tas-motorsports
We Appreciate The Reply!
We were just kind of wondering what the differences were between the two frames...
Happy Holidays,
Mathew
Old 12-25-2006, 01:29 AM   #6
vern350
like a rock
vern350's Avatar
i'll be doing this swap soon. I'll be making a 2wd 3/4 ton pickup into a 3/4 ton 4x4 with a parts suburban. I'll also be converting to a TBI system. I'll be making a similar thread to this one on my project. http://67-72chevytrucks.com/vboard/s...d.php?t=168231
BTW, welcome
Brian
vern350 is offline   Reply With Quote
Old 12-25-2006, 04:08 AM   #7
Stano
Stano's Avatar
I am going to be doing this swap soon with a crew cab. It has a one ton dimension frame(taller and thicker steel than a standard 1/2 or3/4 ton frame even though it is a C-20. I have a 4x4 frame to rob all the crossmembers off of as well as the steering box and motor mounts and such. The main thing is keep good measurements for mounting the front spring rear trunions in and you will need to remove your rear spring hangers and use the ones off of a 4x4 in the rear. Has anyone done a swap like the one I am doing? What did you do about the taller frame? Hey Taz if you run into a snag let me know and maybe I can help out. They say two heads are better than one. I am going to be doing this swap starting real soon. I have converted several two wheel drives to four wheel but usually started with a four wheel frame. Merry Christmas
Stano
New daily driver 96 Chevy K3500 crew cab dually 53,000 miles 350 Vortec 4L80
Nice ride 67 Chevy C-10 LWB Built 350 TH-400
Wifes ride and family rig:
2001 Furd Expedition 5.4 Liter
Kickin back in Rolla,Mo. USA
"Do the thing you fear most and the death of fear is certain" Mark Twain
Stano is offline   Reply With Quote
