Old 08-21-2002, 08:30 PM   #1
OLDCHEV4X4
OLDCHEV4X4's Avatar
Valve Spring Micrometer
I just got a Tavia valve spring micrometer from Summit and am dissapointed in the quality for the price i paid. The mic is suppost to be accurate to .001 but the graduations are to .005 .. At 1.700 the threads have .01 slop and when you turn the barrel the threads get tight then loose, tight then loose.. I know that acceptable valve spring tolerance is +- .02 , but this tool falls short of being called a micrometer in my opinion. Does any one know where i can get a quality mic?
Randy
72 k/10 short wideside
72 k/5 Blazer
72 K/5 Blazer - obstacle course racer
72 custom/10 8' bed
70 K/5 Blazer
67 C-30 GMC Flat bed
86 GMC K2500 Plow Truck
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
72 Sears 12hp Tractor
Glenmoore, Pennsylvania
OLDCHEV4X4 is offline   Reply With Quote
Old 08-23-2002, 01:51 PM   #2
JimKshortstep4x4
Smile
Have you considered a digital caliper? I use mine for lots of measurements and it is pretty accurate. I like it because it repeats, can be zeroed out, and it is for id and od measurements.
Jim
Old 08-23-2002, 04:05 PM   #3
OLDCHEV4X4
OLDCHEV4X4's Avatar
I cant get down in the spring pocket with the I.D. anvils on a dial caliper.
Randy
72 k/5 Blazer
72 custom/10 8' bed
70 K/5 Blazer
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
Old 08-24-2002, 04:58 AM   #4
O'l Buck
Recovering Truck Driver
O'l Buck's Avatar
you might try Starret, they make some high quality measuring tools, not sure about a valve spring mic though.
67 K-20 350, SM465, Eaton rear, 4.56 no spin option
00 Dodge 2500 4x4, 24V cummins, 5 speed
Chad
South Central Nebraska
O'l Buck is offline   Reply With Quote
Old 08-24-2002, 10:37 AM   #5
MikeB
MikeB's Avatar
I simply use a 6" steel ruler with graduations at .100" and .010". I can definitely tell the difference between 1.690", 1.700", and 1.710" installed height. And that's good enough considering the smallest shims I can find are 015". If you need more acuracy, use a maginifying glass -- seriously! I have a cheapo plastic one that I use from time to time. Yeah, plus or minus .020" is probably good, as long as you're not flirting with coil bind. Crane recommends a .060" margin of error when calculating max lift for a spring at a given installed height.
Mike
1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- sold
1981 C10 Silverado LWB -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
