Old 12-25-2006, 03:45 PM   #1
Blue85
Oilfield Trash
Blue85's Avatar
96-98 350 vortec swap
Anyone swapped a 96-98 350 vortec into a 67-72, If so, any problems? Complaints? i know there is a lot of 5.3 swaps around, but dont remeber seein the older 350 vortec. i came across totaled off truck for real cheap, thats why i am thinkin about it, plus I can use al of my brackets and mounts and s**t like that.
14 Dodge 3500 Mega Cab
08 Dodge 3500 Mega Cab
87 Chev 3+3 4x4
80 GMC K10 High Sierra bone stock
70 Chevelle 350SS long term project
68 GMC 3ton Grain Truck/Garbage wagon
50 Pontiac 2 Door Coupe Project
"I've got a shotgun rifle and a 4 wheel drive and a country boy can survive" Hank Jr.
Blue85 is offline   Reply With Quote
Old 12-25-2006, 04:10 PM   #2
HeavyD
HeavyD's Avatar
Re: 96-98 350 vortec swap
Planning to swap to carb or keep injected? From what I understand you have to use an electric fuel pump on the vortec engines, but the rest should be a bolt in swap with just a new intake (Edelbrock 2116 for example) needed. For injection, someone with wiring experience should be able to help out here.
"You can take the man out of PA, but you can't take PA out of the man"
HeavyD is offline   Reply With Quote
Old 12-25-2006, 04:49 PM   #3
QKENUF4U
QKENUF4U's Avatar
thats a swap i would like to do. i used to have a 96z71 w/ the first year votec and it ran really well. would be a blast in my 71. if ya have the whole truck i would think it would be pretty easy.
QKENUF4U is offline   Reply With Quote
Old 12-25-2006, 08:16 PM   #4
1972CheyenneSuper
1972CheyenneSuper's Avatar
I'm in the progress of doing the swap. I've got a 350 Vortec out of a 99' Suburban with 4 wheel drive so I've got the oil cooler too. (They still had the 350's in the Suburbans and vans even though they went out of the trucks in 98.) For the wiring I went with the Painless harness. It is very expensive and although I have not put it in yet, every connection is labeled and it looks very easy to install. It also has the plug to use the 4l60 or 4l80 if you plan on using one of those. I've got a new rebuilt 4l60 for mine. Right now I'm currently working on the fuel system, figuring out what pump, tank, lines, etc. that I'm going to use.
My build thread here:
http://67-72chevytrucks.com/vboard/s...d.php?t=190306
Also Tim240Z, has done the swap. He's got various threads if you just search through them. If you have any other questions I'll try to be of some help.
1972CheyenneSuper is offline   Reply With Quote
Old 12-25-2006, 09:48 PM   #5
shaneschevys
Its always something!
shaneschevys's Avatar
I have a 98 350/4l60e combo in my 72 swb & a 96 305/4l60e in my 72 suburban.
79 p10 stepvan
72 Short Fleetside
72 Suburban
67 GMC One Ton Flatbed
64 Short Fleetside
57 Chevy 2DR Hard Top
57 Chevy 2dr wagon
65 f*** short fleet
63 C 60 Flatbed
Member of the patina club
shaneschevys is offline   Reply With Quote
