Old 12-25-2006, 07:54 PM   #1
68_2_H8
Lowering jobs - what parts did you use?
Just wondering, I'm getting ready to purchase new A-arms, and either fabricate the rear setup using the factory links, or purchase a setup, but the goal is to get the burban laying flat.
Wanted to know what products some of you have used? How do they hold up and work? Anything to stay away from?
Also, what's the largest size (overall diameter) that will fit in a Suburban - up front and still lay flat on the ground?
Thanks,
Dave
68_2_H8 is offline   Reply With Quote
Old 12-25-2006, 08:24 PM   #2
Hart_Rod
Hart_Rod's Avatar
Re: Lowering jobs - what parts did you use?
Check this link out:
http://67-72chevytrucks.com/vboard/s...d.php?t=200387
Hart_Rod is offline   Reply With Quote
