Old 04-24-2002, 06:50 PM   #1
Dean23
68cst_ss490
Dean23's Avatar
Post motor mount position
What is the correct position for a v-8 in a 68 pickup. mine was sitting with the mounts right at the back of the x memeber. my trany has a short tailshaft on it as well. I'm probably going to get a x member and control arms out of a 79 pickup. How easy are they to swap in
Dean
edmonton,canada
68 c10, project in works,350, th350, plain jane.
SLOW AND STEADY GETS THE PANELS READY
http://communities.msn.ca/MyChevytruckpage
Dean
edmonton,canada
a winter wonderland
2005 Chevrolet Avalanche LT
cold air intake, performance exhaust, Comp cams cam, jba shorty ceramic headers.
http://www.cardomain.com/ride/3090973
Dean23 is offline   Reply With Quote
Old 04-24-2002, 08:32 PM   #2
69 longhorn
Post
Factory V8 smallblock has the stands bolted to the front of the crossmember(2wd). The stands are also different than the 6/250 stands. You can set the engine in on the 6/250 stands, for a little weight transfer,but the HEI dist will fit a little snug to the firewall,but will clear. I havent swapped a later crossmember,so cant really say on that one........69
http://community.webshots.com/user/hotrodhorn
69 longhorn is offline   Reply With Quote
Old 04-24-2002, 08:34 PM   #3
Dean23
68cst_ss490
Dean23's Avatar
Post
the 283 that was in there was close to the fire wall. i couldn't pull the hei with the cap on, but with it off it would slide right out. Does anyone have a pic of which holes to use
Dean
edmonton,canada
Dean
edmonton,canada
a winter wonderland
