08-21-2002, 09:27 PM | #1 |
92 350 Heads
92 Chevy 350 heads...194 intake and 160 exhaust.....will an old style intake bolt to these heads? There not vortec, so I'm guessing my "normal" Wiend intake will bolt to these???
I dont have the heads yet, or I'd just look at the bolt holes. Thanks....
Patch |
08-22-2002, 06:33 PM | #2 |
When GM went to fuel injection they changed the angle of the 4 center (2 each side) bolts.On some intakes you can file them out and make it work.Better check those heads.I heard they're bad about cracking and I've never heard of any performance gains between them and older 350 heads.
08-22-2002, 08:11 PM | #3 |
its all about the +6 inches
Actually, the fuel injection started back in the early 80's. Here are some I.D. things too look at to figure the years.
I have a looong list that starts with the '55 265 Cubic Inch. Cross Fire Injection started in '81. TPI started in '85. Center bolt valve covers and a one pce rear main seal came in '86. Roller cam provisions and new angle intake holes started in '87.So, no, your old school intake is not a direct bolt on. Last edited by Longhorn Man; 08-22-2002 at 08:23 PM. |
08-22-2002, 10:27 PM | #4 |
Got big-block?
It'll fit. Just elongate the 4 center bolt holes.
I've done it several times. SC
'68 CST SWB factory 396/T400 buddy buckets, a/c, ps, pb '72 Corvette convertible 454/4spd/ac, ps, pb '73 GMC Sierra Grande short wide 454/T400 ps, pb, ac '77 K5 Blazer black on red, 350/T350/NP205 ps, pb, ac all original '78 GMC Sierra Classic short wide 454/T400 ps, pb, ac '72 GMC Sprint SP454. 1 of 38 built. '73 GMC Sprint SP454. 1 of 71 built. '75 GMC Sprint SP454. 1 of 25 built. SOLD! '72 GMC K25 4x4 468/4L80e/NP205 build thread http://67-72chevytrucks.com/vboard/s...23#post4324423 SOLD!'55 Chevy gasser 496/4spd build thread http://67-72chevytrucks.com/vboard/s...96#post4324396 |
08-23-2002, 01:59 AM | #5 | |
actually 87 was the TBI and center valve cover bolt holes year, 86 was first of one piece rear, yeah 86 are stil carb fed, cept for TPI and crossfire, TPI were still conventional heads, no center bolt cover heads at all til 87 aftermarket companies make carb intakes for center bolt heads(non-LT1) and if you went to trouble of filling the two center tapped holes in each head, and redrilled the holes and 3/8" tapped them to the 87-up angle then you could use a caveman intake on the heads you ask about, ive heard of it being done and someone did somewhere, and i dont rememeber where, its been too long since i saw it, too many computer crashes ago,,, good luck Last edited by Fast68Chevy; 08-23-2002 at 02:06 AM. |
