Old 12-25-2006, 10:38 PM   #1
TP from Cntl PA
TP from Cntl PA's Avatar
2 Hi to 4 Hi and back is hard to shift? Why?
I've only used my 4WD on my K acouple times now, both times I just needed to kick it into 4x4 to get out of the yard(AKA 4Hi)...........Anyhow, it shifts into 4Hi ok, you run it to where you need to go, then try to shift back out to 2 Hi, and it is next to impossible. Had to unlock the hubs to get it today, as it was like the front end put everything into a bind. Is this normal for these to do this? I never had anything 4x4 that was this old, only 4x2's and I sorta miss being able to kick it in and out with ease.
'72 K-20 EFI'ed 250 Inline/4spd stake body, Farm Truck
'71 C-20 Cummins Diesel Powered, In storage thanks to $5.00 diesel!
'69 3500 GMC 305V-6/4spd, Still under reconstruction..........
Inlines Rule! 6 soldiers standing is better than 8 laying down!!!!!!!!
TP from Cntl PA is offline   Reply With Quote
Old 12-26-2006, 01:36 AM   #2
72 CustomCamper
huh ???
72 CustomCamper's Avatar
Re: 2 Hi to 4 Hi and back is hard to shift? Why?
Next time try shifting it back into 2x on the fly. While sitting still the front end can put enought strain on it to not allow it to shift easy...
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's
"I am a bomb technician. If you see me running try to keep up!"
72 CustomCamper is offline   Reply With Quote
Old 12-26-2006, 08:08 AM   #3
TP from Cntl PA
Tried it, you can't move the stick.............
Old 12-26-2006, 09:17 AM   #4
Troy-Built
If it is not used very often it can be tough. Make sure there is no strain on the drivetrain when you shift back. Get up to about 20 and level off on the gas pedal like coasting then try it. You may need to grease the shafts on the transfer case. Also, if you have a 205 transfer case there is a grease zert on the pivot shaft of the shifter. A 205 has 2 shafts and a pivot bar connecting them together coming out of the upper front of the transfer case.
69 Chevelle SS 375/396 TKO 600
71 Suburban 3/4 4x4 402 5-speed (project)
68 chevy C10 shortbed 327 5-speed (project)
72 Blazer 4x4 400 4-speed (wifes project)
Numerous 67-72 parts trucks
Troy-Built is offline   Reply With Quote
Old 12-26-2006, 12:33 PM   #5
TP from Cntl PA
Did grease the shafts.............Right after I bought it it shifted very hard, I mean it took two hands to shift it. I found that the pivot bolt was seized to the shaft, also wasn't a grease fitting on this one. So we freed it up, and I put a fitting in the shifter, also lubed all pivot points in the area. Shifts nice into 4Hi, just hard to get back out into 2wd. I'll play some more with it, maybe I am just to used to the newer Fords.
Old 12-26-2006, 03:40 PM   #6
scotto0609
Junior Member
Before shifting out of 4hi or low try putting it in idling in reverse for about 10 or so feet. That should unload any binding in the drivetrain.
scotto0609 is offline   Reply With Quote
Old 12-27-2006, 04:50 PM   #7
1969K10
1969K10's Avatar
Most of the time, mine shifts out just fine, but everyonce in a while it doesn't want to. i have found that means i've got the X-fer case bound up. Back up and try again. or drive it forward a while longer until something slips and gives... it'll usually move real easy after that...
1969 K10 - V8, 465, 205, 12 bolt, D44 2002-current
1969 K20 - V8, 465, 221, Eaton, D44 2012-current
Nothin' but drums on all 4 corners!
past horses in the stable
72 C10-short step (97-02), 68 C10-long fleet (06-12)
1969K10 is offline   Reply With Quote
Old 12-27-2006, 05:56 PM   #8
Burt4x4
Burt4x4's Avatar
mine can be stiff at time too and I use the forward backward trick while trying to shift and it pops out eventually...
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 12-27-2006, 09:34 PM   #9
jacobs
jacobs's Avatar
Make sure all four of your tires are exactly the same tread, size and worn the same amount front and rear. Although not likely different, but are your front and rear gear ratios the same?
jacobs is offline   Reply With Quote
Old 12-28-2006, 07:19 PM   #10
Zoomad75
K5Camper
Zoomad75's Avatar
My 205 shifts from 4hi back to 2hi pretty easy. Most of the time. if it don't I just back up a few feet and try again.
Rob Z.
1975 K5 350/465/205/D44/12b 4" lift on 35's- RIP
1991 K5 8.1L/NV4500/241/D44/14b FWC Camper
Zoomad75 is offline   Reply With Quote
