![]() Join Date: Sep 2005
parking brake question
out got a quick question on my parking brake you use to be able to set the brake it and would lock the pedal automatically it stopped doing it i now got to reach under there and push the little lever to hold the pedal is there a way to fix this without replacing the hole thing?
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
Re: parking brake question
the return spring broke or somehing siezed. get stiffer spring.... or lube it.. pics?
that same thing happened to me. the whole mechanism was frozen. wd-40 and some tlc sure helped. now i have to fix the rear brakes so the parking brake lever can do something
1969 GMC 3/4 ton, 307, 4-speed NP435GL, DANA 60, 4.10, HD rear leafs, manual everything, leaking oil and water. Now rocking 383, NV4500, power steering, power brakes. Finally undergoing restoration. |
well the park brakes work i can reach under the dash and press the little lever that hold the peda; so i am thinking the spring is broke
