Old 12-27-2006, 08:58 AM   #1
69lowNlong
need help lowering!
i just got my 3/5 drop for christmas and i plan to do it but i have no instructions...is there anybody on here that has a DIY or HOW TO? also i am going to do shocks, relocator and the rear bar for the axle can i just get some pics or some help! Thanks
FOR SALE 69 c10 LWB...best offer
69lowNlong is offline   Reply With Quote
Old 12-27-2006, 09:04 AM   #2
see ten
WTB this ad
see ten's Avatar
Re: need help lowering!
I don't know if there is a FAQ on the board but try www.earlyclassic.com . Click on tech articles, there are several write ups on dropping these trucks listed. Some of these articles use bags in the rear but I think the principle is quite similar.
see ten is offline   Reply With Quote
Old 12-27-2006, 10:05 AM   #3
jlaird
jlaird's Avatar
I can't think of any how-to, but if you have some specific questions, I'm sure we could help.
jlaird is offline   Reply With Quote
Old 12-27-2006, 10:46 AM   #4
2500HD
2500HD's Avatar
I just finished doing this.
1. Spray every nut and bolt with penetrating oil.
2. Remove shocks
3. Remove upper shock mount and install new one
4. Remove track arm
5. remove and replace springs
6. Remove passenger U-bolts -- do one side at a time
7. Install track arm relocator, shock mount relocator and U-bolts
8. Remove driver side U-bolts
9. Install shim, shock relocator and U-bolts
10. Install shocks
11. center rearend at ride hieght and install track arm
2500HD is offline   Reply With Quote
Old 12-27-2006, 12:12 PM   #5
69lowNlong
thanks for all the info but no how to on ece
Old 12-27-2006, 01:12 PM   #6
2500HD
2500HD's Avatar
My kit was from ECE. The shock relocator kit and the track arm kit cam with instructions but it did not say in what order everything should be done. I did everything as discibed above and all worked out fine. What exactly do you have concerns about?
Old 12-27-2006, 01:44 PM   #7
69lowNlong
ok will see how that works
