Cochino_Racing_909
Need Some Info!
Does Anyone Know where I can get a good deal on a 40Gallon tank for my 72 Jimmy?
The LuvShack Garage
Re: Need Some Info!
There was a member here making them for awhile, his ID is Fuelcellguy,
not sure if he is still making them or not, he's been kinda MIA as of late. http://67-72chevytrucks.com/vboard/member.php?u=8871
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Big Piggy: "Goliath" 07 Kodiak C4500 Lil Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T Last edited by LUV2XCLR8; 12-27-2006 at 01:40 PM. |
Re: Need Some Info!
I put a 37 gal tank in my K5 from thease guys:
http://www.nwmp.com/ Not too cheep if I remember it was around 400bucks and it hangs lower than a factory tank. I modified mine to mount higher cuz I have a bodylift... Good luck
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks ![]() |
Cochino_Racing_909
Re: Need Some Info!
Have any pics?
Re: Need Some Info!
JC Whitney also sells those Northwest Metal Products (nwmp) tanks. You can probably find a picture on their web site.
Tim |
Re: Need Some Info!
What about getting a later model blazer/burb tank from a bone yard?
Might not be 40 gallons but their larger than the one that's in there for sure. |
Re: Need Some Info!
Here is one I found, I made the skid plate for it....
![]() That is the only one I could find... basically thoes two center straps hold the tank up to the frame. I relocated the tabs that touch the frame to a lower spot on the tank so it mounted higher. The factory rear crossmember was removed too, not a problem for me cuz of the hitch I have on the end of the frame acts like a crossmember/rock skid ![]() I think I read someware about thoes chevy 31 gal tanks working but you have to install it backwards to line up the filler neck ~ going off memory so I could be wrong ![]()
