Old 12-27-2006, 09:25 PM   #1
cochino12
It followed me home?
cochino12's Avatar
81-87, 3/4 ton frames taller?
How much difference is there between 1/2 ton and 3/4 ton frames? I cant seem to find a nice 3/4 ton anywhere so I think I might just buy a clean 1/2 ton and swap axles/springs. Is that the only difference?
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 12-27-2006, 09:48 PM   #2
magnethead
7000 #'s of american IRON
magnethead's Avatar
Re: 81-87, 3/4 ton frames taller?
hangers are different (i think theres a 2" length difference?) and here probably is a frame difference.
magnethead is offline   Reply With Quote
Old 12-27-2006, 10:34 PM   #3
desertrat
desertrat's Avatar
If you don't get any answers to this today I will measure my '86 3/4 ton frame for you tomorrow.
desertrat is offline   Reply With Quote
Old 12-27-2006, 11:08 PM   #4
cochino12
cochino12's Avatar
Great, thanks
Adam
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Old 12-28-2006, 04:16 PM   #5
desertrat
desertrat's Avatar
The frame rails on my '86 3/4 ton 2wd are 8 1/8" tall
how tall are 81-87 1/2 ton frame rails? I know my '71 is something like 6"
Old 12-28-2006, 09:22 PM   #6
Russell
Professional Grade
Russell's Avatar
all 1/2 ton and 3/4 ton frame rails are identical, 2wd or 4wd. They are all the same part number. Only difference is the bracketry bolted to them
The 1 ton frames are very different though, much thicker, and much heavier duty.
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 12-28-2006, 10:44 PM   #7
cochino12
cochino12's Avatar
Thanks for the taking the time to measure desertrat.
Russell thank you also. Thats just what I needed to know
Adam
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
