12-27-2006, 10:20 PM | #1 |
Name of part on Front Suspension
Hey Everyone,
Any one know what the middle link that the tie rods/pitman/idler arm bolt to? I need the name so I can ask for one and help with a source to get one as mine is very bent and rubbing against the K member. No wonder the steering was so difficult. Thanks! Last edited by whatnow123; 12-27-2006 at 10:21 PM. |
12-27-2006, 10:32 PM | #2 |
Re: Name of part on Front Suspension
Are you talking about the "DRAG LINK" ?????
12-27-2006, 10:39 PM | #3 |
12-27-2006, 10:48 PM | #4 |
The Older Generation
I think you are talking about the tie rod. The idler and pitman arm connect to the ends and the tie rod ends are connected to it inboard a few inches from each end. I think a drag link would go from a pitman arm to a steering arm. LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 12-27-2006 at 10:54 PM. |
12-27-2006, 10:57 PM | #5 |
Could it be the center link?
12-27-2006, 11:21 PM | #6 |
Heres a generic pic of a truck front suspension, i'm thinking your looking for the center link.
What year and model is your truck? I have an old moog catalog in the garage. I have used it a few times over the years, the part #'s dont seem to change, but some have been discontinued. .
68 GMC 64 1/2 Mustang convert A bachelor's life is no life for a single man." - Samuel Goldwyn |
12-27-2006, 11:23 PM | #7 |
PROJECT 7DEUCE
center link would be my guess..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
12-28-2006, 01:28 AM | #8 |
x2 Center link The idler arm supports the center link pn the passenger side, the pitman arm transmits the steering input to the center link and the center link ties the drivers side and passenger side inner tie rod ends together... Speaking of center links, who sells new ones? I have all new front end components I picked up at Napa but they had no listing for a center link...
Project Family Values Build Thread Vehicles/Projects: -1971 C10 SWB Fleetside! Gathering parts now, will begin frame-off resto soon... Pleasure in the job puts perfection in the work. -Aristotle |
12-28-2006, 07:37 AM | #9 |
blood type; Retumbo
either the dealer or a bone yard. since it is not a wear item the aftermarket doesnt cover it.
12-28-2006, 09:23 AM | #10 |
'71 chevy s.bed/s.side
whatnow123...PM sent
STILL PLAYS WITH CARS...AND TRUCKS!! Parents! Be good to your kids...they get to choose your nursing home! 250 I-6 with a 3 speed Saginaw and Borg Warner Overdrive...She's got overdrive! |
12-28-2006, 11:29 AM | #11 |
Gone Fishing
Most auto parts places consider it a centerlink. Some do refer to it as a drag link. The part between the tie rods ij the tie rod adjusting sleeve.
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop Frame of resto has been started 2022 Hyundai Tucson Limited 2019 Chevy Traverse Redline Edition Wifes Ride Build Thread http://67-72chevytrucks.com/vboard/s...=1#post3483616 |
12-28-2006, 12:59 PM | #12 |
Born Psycho
it's called a center link and are different between disc and drum trucks
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
12-28-2006, 01:10 PM | #13 | |
So I have to find a drag link from a power steering equipped C10? Anyone know if interchanges for this part? |
12-28-2006, 02:16 PM | #14 |
Im going to throw a question in here...hopefully it will help in the end.
I have a '73 Blazer and from what I understand the front suspension is pretty much the same as the '72 trucks right? Maybe the inner tie rod hole on the center link is different? I have seen the center link for sale in the LMC catalog for the '73 and up but not for the '72 and down. So maybe if you got the '73 center link and inner tie rods (with adapting tie rod sleeve) it may work?
1986 C10 - LWB, 305/700r4, posi, vortec heads |
12-28-2006, 02:46 PM | #15 |
member #16
Whatnow123 Jerry said disc and drum were different, not power or no power.I imagine it has to do with the tie rod end size.
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors http://www.flickr.com/photos/1745471...7602865984234/ |
12-28-2006, 08:05 PM | #16 |
I am a Referee of life.
I looked and here is the info I found.
1968Chevrolet Truck Chassis Service Manual They call it a Steering connecting rod.They tell how to replace it but not any part#'s or anything. Haynes Chevrolet and GMCPick-Ups 1967 thru 1987 Steering linkage relay rod (This is from the description of removing the crossmember[the only reference I could find]) My Chevrolet Pickup parts interchange manual 1967-1978 doesn't adress the part at all. Break out the books boys"Inquiring minds want to know"
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" Last edited by PanelDeland; 12-28-2006 at 08:07 PM. |
01-01-2007, 01:08 PM | #17 |
Try PST Suspension. They are very good with front end parts and reasonably priced too. By the way, ask for a center link anywhere and they will know what you want.
01-02-2007, 12:27 AM | #18 |
in a 4runner it's called a relay rod, and it's under recall haha, just had it replaced for free on the 1990 4runner of mine
