Old 12-28-2006, 10:52 AM   #1
62ChevyStep
62ChevyStep's Avatar
Front End Suspension Rebuild Kit
Over here from the 60-66 forum, swapped in a 86' front end in my 62' to replace the factory torsion bar setup.
need to rebuild the front and was wondering who you can recommend for complete kits.
________________________
62' 3.5/5 drop SWB Fleet, PS, PB-Dsk/Drm,350/700R4
08' Chevrolet Silverado CrewCab
05'Toyota Tacoma Prerunner SR5
62ChevyStep is offline   Reply With Quote
Old 12-28-2006, 01:36 PM   #2
craig@ridetech.com
Formerly LSC71
Re: Front End Suspension Rebuild Kit
I've used the kits from PST before and had very good luck with them. Otherwise just piece it out from your local auto parts store.
craig@ridetech.com is offline   Reply With Quote
Old 12-29-2006, 04:43 PM   #3
boxrodz
Until Seventy Times Seven
boxrodz's Avatar
As LSC71 said, PST has a good reputation.
But, when I rebuilt my front end, I wanted to maintain the stock rubber bushings. I purchased the control arm bushings and the center link from a dealership (AC/Delco parts) and the remaining parts from the local auto parts store (Perfect Circle). BTW, Federal Moog is a good manuafacture of suspension parts.
Here's a past thread on rebuilding the front suspension, http://67-72chevytrucks.com/vboard/s...d.php?t=189574. I have a couple of procedures on replacing the upper and lower ball joints in detail, if interested.
boxRODz
1983 C10 SWB Fleetside
When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son.
You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin...
boxrodz is offline   Reply With Quote
Old 12-29-2006, 04:55 PM   #4
kevinr1970
Why the stock bushings as opposed to a poly-urethane or poly-graphite? Or did the kit come with crappy rubber bushings?
2009 Honda Fit CfC (bsf 44.9 mpg)
2000 Tahoe Limited
1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below
1991 GMC CrewCab Dually 4x4, just going to fix things up for now
1982/1989 K5/GMC Jimmy 2wd
1987 GMC 1/2 ton swb 2wd Crew (sold)
kevinr1970 is offline   Reply With Quote
Old 12-29-2006, 08:42 PM   #5
N2TRUX
Happy to be here
N2TRUX's Avatar
Go with poly-graphite from PST. Do not use straight urethane bushings unless you enjoy squeaking noises...
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 12-29-2006, 09:32 PM   #6
pcmcobra
pcmcobra's Avatar
just bought a front end kit from pst this afternoon.
woohoo.
pcmcobra is offline   Reply With Quote
Old 12-30-2006, 12:34 AM   #7
62ChevyStep
Thanks everyone, I appreciate the information!
Old 12-30-2006, 05:50 PM   #8
boxrodz
boxrodz's Avatar
I don't believe the PST kit offer rubber bushings. At least they didn't when I rebuilt my front suspension.
I went with rubber bushings because I wanted to absorb as much road vibration as possible... an advantage over the polys. But, at the same time, they have a bit more flex than the polys. A disadvantage if you're looking for performance.
boxRODz
Old 12-31-2006, 11:30 PM   #9
71'tahoe
71'tahoe's Avatar
I have a 65 how hard is it to swap the front end from a 77' i know it looks like a bolt in swap but just checking before i tear it down.Thanks
71'tahoe is offline   Reply With Quote
Old 01-02-2007, 02:21 AM   #10
fishmunger
fishmunger's Avatar
i have a 64 with a 77 front suspension in it. The previous owner did it but told me the crossmember was bolt in, u just have to elongate 2 holes. other than that he said it was a piece of cake...take it with a grain of salt though as I have no firsthand experience with the mod.
Check out chevytalk.com as the 60-66 forum over there is very active and this topic has been beat to death over there 100000000+ times and those guys will be able to give you all the details for sure...
Nate
fishmunger is offline   Reply With Quote
Old 01-02-2007, 10:38 AM   #11
pcmcobra
pcmcobra's Avatar
p-s-t has the rubber kits...
Old 01-02-2007, 11:18 AM   #12
craig@ridetech.com
Formerly LSC71
The only thing you really need to swap are the control arms and the spindles. If you use the 77 parts they should bolt right up to the 65 crossmember.
