Old 12-28-2006, 05:12 PM   #1
stynchrr
stynchrr's Avatar
Trans cooler lines
Where can i find trans cooler lines for a 87 GMC Jimmy witht a 700r4 and 4wd? they are not listed in LMC or any of the online parts stores i have looked at. can any one help?
stynchrr is offline   Reply With Quote
Old 12-28-2006, 06:33 PM   #2
edman87
junk collector
Re: Trans cooler lines
Aren't they rigid lines? If so, go to the local parts house and get a length of straight flared end tubing of the right size and bend to fit, should be 1/4"? Doing this is the same asbrake lines. If it has a lexible part or somthing(I can't remember, but don't think so) let me know and I will see if I can hook you up with 1 of my old sets. My 89 should still be in there as the trans is the only thing removed right now, and the lines from my 87 are somewhere around here as it now has a sm465 instead of the orig 700r4.
'87/89/76 K5 in progress
'99 K2500 short crew
'91 camaro rs
'98 jeep tj
'52 willys cj3a
edman87 is offline   Reply With Quote
Old 12-29-2006, 09:10 AM   #3
stynchrr
stynchrr's Avatar
Do you know if the turbo 350 lines would work?
