Old 12-28-2006, 11:14 PM   #1
swb70
Unhappy p/s install 72 into 70
My 70 6cyl has no p/s. have 72 w/ps and 350v8/350 auto. going to put the 350/350 into my 70. Want to put p/s in the 70 also. ?will p/s gear box bolt on and will the steering column bolt in also, want to use the column out of the 72 so I will maintain the 350 shift pointer. What other problems will I encounter. Will it be a simple bolt on project?
swb70 is offline   Reply With Quote
Old 12-28-2006, 11:27 PM   #2
arkracing
Weekend Warrior
Re: p/s install 72 into 70
should be a simple bolt in set-up.
Steering box should fit - if the frame is a early '67 it may not have the dimple for the steering box....but being a '70 it should already have it. I put a '73+ p/s box in a '69 frame with no issue - bolts right in.
-'07 GMC Sierra K2500HD
-'66 C10 Suburban
-'68/'71 K20 Service Bed Project
-'69 Chevy C30 Mason Dump
-'33Ford P/U 396ChevyPowered
arkracing is offline   Reply With Quote
Old 12-28-2006, 11:36 PM   #3
swb70
Thanks ark. I was hoping that would be the case..
