Octane????
I have a 68 stepside with a mystery 327. She runs great since I bought her and came with a lil bit of goodies. Headers, Edelbrock Carb, performer intake and after market Hei were found under the hood. I was wondering what Octaine I should run in her. The guy I got her from wasn't mechanically inclined and just put gas in it. When I got her I put in chevron and drove her 90 miles home at 70 all the way. I took a chance broke water pump, leaking radiator, belts were off alighnment, bent fan, no shroud, wrong gap plugs, but I still drove her on a summer night in central cali home happy....I got most of the corks out she has a lil tapping of the rockers but will take care of that soon. She runs strong but I want to preserve the engine as much as I can so I can focus on body, frame and suspension mods (drums all the way around). I'm going to fit her in the rotation of my other two cars, figure I'll drive her every last day of my work week no matter what. My 3 year old daughter already wants me to drive everytime were hanging out and I do plan on taking her to local and posibly a few times to the costal shows 3 hours away this spring and summer. What ocatain recommended on posibly stock 327 with bolt ons.....?
Re: Octane????
Cant you there but
RIP to my son Dylan. 5/17/2002 - 8/18/2018 If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started. https://slothforpedcancer.org 68 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=223234 |
Re: Octane????
I'd think if it was actually a 327 built in the sixties, it would appreciate leaded gas for starters. Aside from that, if your happy with the timing and it's not pinging running regular gas in it, it should be cool. If it is a high compression engine, you may want to use higher octane. But considering it's not pinging, you should be fine.
04 4x4 GMC Ext. Cab lifted 71 2wd GMC / Ramjet 350 ready for sheet metal 49 Studebaker pickup |
its all about the +6 inches
Re: Octane????
if it doesn't ping, then you are literally burning money.
Re: Octane????
If Performance is King, I'd set the timing at about 34 to 36 degrees total advance and then increase the octane in the gas I buy until the pinging stops. Or, if money is King of the Equation, run 87 Octane/regular and retard the timing 1 or 2 degrees at a time until the pinging stops. If it only pings on occasion/under unusual circumstances, then I'd leave things as is and let it ping once in a while. JMO.
69 C-10 SWB Fleetside 454/TH400 (For Sale) http://67-72chevytrucks.com/vboard/c...ct=1299&cat=12 70 El Camino 454 TH700 29 Model A 4-DR Sedan Deluxe |
