Old 12-29-2006, 07:31 PM   #1
skokie
skokie's Avatar
Need power steering hose routing
Can someone tell me or post a pic of how the power steering hoses are supposed to be routed for a 68 1/2 ton v8? I going to change out the steering gear in a few weeks and replace the hoses.
RIP to my son Dylan. 5/17/2002 - 8/18/2018
If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started.
https://slothforpedcancer.org
68 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=223234
skokie is offline   Reply With Quote
Old 12-29-2006, 07:54 PM   #2
rage'nrat638
rage'nrat638's Avatar
Re: Need power steering hose routing
i am thinking a 69 might do
rage'nrat638 is offline   Reply With Quote
Old 12-29-2006, 08:03 PM   #3
skokie
skokie's Avatar
Thats what I am looking for. Thanks
68 build thread
Old 12-29-2006, 08:11 PM   #4
skokie
skokie's Avatar
Found this digging through the factory assembly manual.
68 build thread
Old 12-30-2006, 02:05 AM   #5
nandress
nandress's Avatar
Yeah, if you can follow it!!
Unfortunately found numerous instances in the assembly manual where the drawings are not exactly clear...or worse, bassackwards!
I wired mine up in about the same way as rage'nrat638's pictures, and I really hope it works!!
nandress is offline   Reply With Quote
Old 12-30-2006, 07:22 PM   #6
skokie
skokie's Avatar
Yep seen that in the pages from the assembly manual before.
68 build thread
Old 12-30-2006, 07:32 PM   #7
Boog
laying low
Boog's Avatar
Skokie, didn't the 67 & 68 use a slave cylinder power assist steering? That is what that diagram is of. That 69 posted is an integrated sector. What setup does your 68 have?
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 12-30-2006, 07:45 PM   #8
skokie
skokie's Avatar
Boog I found out after i posted that pic that I have the 69+ setup. If you are right then Its back to the book for more pics
68 build thread
Old 12-30-2006, 07:54 PM   #9
skokie
skokie's Avatar
Boog do you have a pic of your setup?
68 build thread
Old 12-30-2006, 08:31 PM   #10
skokie
skokie's Avatar
Well I found another way in the back of the book.
68 build thread
Old 12-30-2006, 08:59 PM   #11
Boog
laying low
Boog's Avatar
Skokie Ragenrat's pic is of the 69 and up setup like mine. If you have the 69 up setup then there's nothing to it. If you are going for the original 67-68 slave cyl assist setup the diagrams you posted are correct for it. Have you tried checking LMC book for pics and diagrams? I may be wrong for the yrs. I'm pretty sure the 67 was a slave cyl assist but not sure on the 68. You'd need to consult a parts listing or someone with the correct setup will chime in here and bail us out.
Boog
primer is finer
Old 12-30-2006, 10:12 PM   #12
skokie
skokie's Avatar
Boog 69 setup is what I am going to keep. I will be replacing the steering gear box since it is leaking from the top.
68 build thread
Old 12-30-2006, 10:53 PM   #13
Boog
laying low
Boog's Avatar
Great. The slave cylinder setups were always plagued with leaks and shuttering and such. You'll be much happier with the 69 up.
Boog
primer is finer
Old 12-31-2006, 03:09 AM   #14
nandress
nandress's Avatar
Skokie, That's an even better one!!! Did you notice how four lines magically turned into two???
Man, now I am wondering how these things ever made it out of the factory door!!!!!!
Wait, and how come it has two pumps.......... Ok, I'm going now...........
Old 12-31-2006, 07:03 PM   #15
skokie
skokie's Avatar
Nandress I sure did. Glad you noticed. I thought it was me
68 build thread
