04-23-2002, 10:00 AM | #1 |
Half a bubble off!
Air Cond. dilemma - vote here!
Here's the dilemma: An air cond. system that still works, but not well, with a small leak somewhere, that was changed over to new variety coolant 3 years ago using a changeover kit from a parts store, that does not really get that cold even when re-filled. Is it worth trying to salvage a 31 year old system, or would it make more sense to go with a new system from Old Air/Vintage Air? Also, how much of a job is it to change over?
------------------[*]'71 Cheyenne, 402BB[*]Winfield, KS[*] http://barn9.freeservers.com
Just call me LB. '71 Cheyenne, 402BB, hauls blondes, brunettes, or redheads. |
04-23-2002, 10:08 AM | #2 |
Fix factory system if it all there.....Old air sells the parts to update to R134 with a new POA valve that converts the sytem to a cycling. Or go with the old parts and try the duracool. Check first hose...then the condenser in front....then compressor front seal.
69 SWB C/10 5-6 drop 700R4 69 Firebird Convert 455 4 spd 70 Torino GT Convert Austin-Texas |
04-23-2002, 11:00 AM | #3 |
Old member
Keep the factory ac and up grade it to a 80's model condensor, and get rid of the poa valve. I have done this to my 71 and it has 134-A also. The upgrade is cheap compared to buying all new stuff. The 80's model cleans up the fender also some, it adds the acumaltor and does away with the drier. You can see pics of it in my signature. Either one has them but the pictur trail has close ups.
------------------ Andy 71's Are for ever!!! or 67,68,69,70,72 71,factory tach,tilt for straight drive,gauges,ac,305 HO TPI with 700-R4 lowered,17" wheels www.geocities.com/chevy71tpi/main.html www.picturetrail.com/Andy4639 [This message has been edited by Andy4639 (edited April 23, 2002).] [This message has been edited by Andy4639 (edited April 23, 2002).]
04-23-2002, 11:05 AM | #4 |
Livin' it up.
I put a whole new system in my truck from Vintage. The work i had to have done cuz i dont know JACK about ac stuff. They had to fab some stuff for the lines running to the (brain fart) thingy in the front of the truck. That was a costly rig since they had to do some modified lines and welding. All in all i think with parts and everythign it was 1400 bucks and i kept the old Frigidare compressor. Thing is cold enuf to make my mom and girlfriend complain all the time and i've got no tint so there ya are. Good luck but i'd say like the others fixing the leak and flushing the system will be your cheapest fix.
------------------ 69 Custom 20, 396BB,Longbed fleetside. New Oak Bed With SS strips... damn nice. Edelbrock performer RPM-O, Edelbrock 750Carb, Headers, HEI, 2 40" glasspacks. Stereo: Classic-style tape deck/radio, 2 6x9 Cerwin Vega's in doors, 2 10" Neo subs under seats, 1 900 Watt amp. SN= Ares220
-Greg; Sold the 69 C20. It's off to a better home with more love! Now onto the 86 CUCV M1009; K5 blazer with 6.2L diesel, corp 10 bolt axles, Detroit locker in the rear, trutrac front, 3.73 gears, 35" tires. |
04-23-2002, 11:12 AM | #5 |
Andy........thats a clever way to update the AC
[This message has been edited by Frank_Zeller (edited April 23, 2002).]
04-23-2002, 07:30 PM | #6 |
Half a bubble off!
Thanks guys! Hey Andy, when the new board gets going, you'll have to give us all a good step by step tutorial on this AC upgrade. I'm sure there are others besides me that know nothing about AC systems. I'll have to get more details to figure it out myself, but thanks for getting me something to go on. Buy the way, I like your truck, especially under the hood!
04-24-2002, 09:03 PM | #7 |
Old member
THE CHANGE OVER WASN'T THAT HARD TO DO. The parts are fairly easy to find, are you can buy new. All of the hoses fit together also.The only thing I should have done is cut the commpressor hose so it didn't curl up like it does. I'm planning on changing the evaprator some time to a late model one when I find one that will work with the hose fittings on the right side.
