Old 12-29-2006, 07:47 PM   #1
lytemup454
lytemup454's Avatar
Question rear disks?
i was wondering if anyone had an idea about do rear disk swap. i'm on a budget as most of us are, so i don't want to do an aftermartet swap. i know i can go the 9in route w/ explorer brakes but i want to keep the 12 bolt and i'm not sure what to do? any advise would be great.
lytemup454 is offline   Reply With Quote
Old 12-29-2006, 07:54 PM   #2
mkhutch
Throbbing Member
Re: rear disks?
I know CPP makes a kit that has the brackets, etc to swap real easy. I also know a lot of people have been swapping Impala SS brakes. I have the CPP kit and is pretty cake.
mkhutch is offline   Reply With Quote
Old 12-29-2006, 07:58 PM   #3
jkade
jkade's Avatar
Re: rear disks?
Get you the rear calipers off a impala ss (94 to 96 year range or a caprice of the same body style. If you want to run the stock rotors I have a set I will give you if you pay the shipping, they are the same bolt pattern as the five lug trucks. There is a guy on here that makes the brackets to mount to the axle if he has any left. I bought my calipers and baskets off www.car-part.com used and powder coated them and that is what they look like. I am waiting on my brackets to get here so I can install. I hope this helps.Name:  kade 050.jpg
jkade is offline   Reply With Quote
Old 12-29-2006, 08:10 PM   #4
lytemup454
lytemup454's Avatar
Re: rear disks?
thanks that a start, would i still be able to run the same clipers if i wanted to go to a bigger rotor?
Old 12-29-2006, 08:20 PM   #5
msgross
msgross's Avatar
Re: rear disks?
someone was selling an Impala SS setup a few weeks ago, check the parts board.
msgross is offline   Reply With Quote
Old 12-29-2006, 08:21 PM   #6
lytemup454
lytemup454's Avatar
Re: rear disks?
good call
Old 12-31-2006, 05:18 PM   #7
JustLiveIt
JustLiveIt's Avatar
Re: rear disks?
I have the setup from abspowerbrake and it uses cadillac calipers and rotors with an emergency brake. The kit is ok but for me it was not a true bolt on application. I had to grind the spacers and use some shims to get the caliper mounting brackets to be paralell with the rotors. While not very difficult, it was time consuming. You should check out the impala SS brakes thread too.
1968 Chev SWB Fleet with GMC Clip and lots of 71-72 parts!
JustLiveIt is offline   Reply With Quote
Old 12-31-2006, 05:28 PM   #8
poorboy
poorboy's Avatar
Re: rear disks?
I was going to run a kit similar to this.
http://www.daymotorsports.com/product/1107/c/B120/#
poorboy is offline   Reply With Quote
Old 12-31-2006, 05:43 PM   #9
blazerboy72
Re: rear disks?
I went with camaro calipers and impala ss rotors. U sing that setup you can retain the parking brake and 5x5 lug pattern. I have $167 in mine including calipers, brackets, rotors, new pads, and parking brake cabels.
blazerboy72 is offline   Reply With Quote
Old 01-07-2007, 11:32 PM   #10
L0WRIDE
L0WRIDE's Avatar
Re: rear disks?
Hey, I'm thinking 'bout doin the same thing, can you plse tell me - what years Camaro & Impala. Parts are quite hard to get ahold of here (Auck, New Zealand) and aren't cheap, so I have to make sure make sure what I source is going to work first pop. Also, did you make your own brackets?.
Cheers, Chris.
49 CHEVROLET 1/2 TON, 52 CHEVROLET SEDAN
62 HARDTOP NOVA
65 CHEVROLET BB LWB FLEETSIDE
90 CHEVROLET EXTRA CAB
CHEVY ONLY - NZ Chapter
http://67-72chevytrucks.com/vboard/s...d.php?t=137984
L0WRIDE is offline   Reply With Quote
Old 01-07-2007, 11:42 PM   #11
Coronas56
Coronas56's Avatar
Re: rear disks?
http://tsmmfg.com/ Check out this company, I bought by disc brake brackets from them.
Coronas56 is offline   Reply With Quote
Old 01-08-2007, 05:44 AM   #12
blazerboy72
Re: rear disks?
I used 94-96 impala ss rotors and 94-96 camaro calipers. I am still working on the brackets (cut the first ones 1/4" too short)
Old 01-09-2007, 04:35 AM   #13
L0WRIDE
L0WRIDE's Avatar
Re: rear disks?
Thanks for that, might be a stupid Q but why couldn't you use Camaro rotors as well?.
62 HARDTOP NOVA
Old 01-09-2007, 05:45 AM   #14
blazerboy72
Re: rear disks?
the bolt pattern is wrong. I think it is 5x4.75 or something like that.
Old 01-09-2007, 07:06 AM   #15
Bishops Trucks
KEEP ON TRUCKIN'
Bishops Trucks's Avatar
Re: rear disks?
I had some Moser Axels made for my 12 Bolt and are 5X4.75, so am I safe to say I could go with the Camaro calipers and rotors on mine. Not meaning to highjack the thread or get people confused. I just could not get the Weld Wheel in the 5x5 bolt pattern so I had new axels made at 5X4.75.
JIM
'97 GMC Sierra K1500
'95 Chevy Silverado C1500
'71 Cheyenne Z71 / LT1 & 4-Speed SWB K/10 Father/Son Project
http://www.youtube.com/watch?v=4l689JKXPnA
"LIVIN' FREE FOREVER"
Bishops Trucks is offline   Reply With Quote
Old 01-09-2007, 08:17 PM   #16
blazerboy72
Re: rear disks?
They should fit fine for you then.
Old 01-09-2007, 11:18 PM   #17
L0WRIDE
L0WRIDE's Avatar
Re: rear disks?
Hi, do you have MM's or drawings for the brackets you are using?.
62 HARDTOP NOVA
Old 01-25-2007, 07:16 AM   #18
L0WRIDE
L0WRIDE's Avatar
Re: rear disks?
whats the thickness of the impala rotor. does anyone know ??
62 HARDTOP NOVA
Old 01-25-2007, 11:25 AM   #19
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: rear disks?
If you are looking for performance gains, spend the money up front. Disks won't do jack in back on an empty pick up. That's why GM went back to drums in back.
If you want bling, then cool, but don't do this expecting to stop any quicker.
