Bondo VS Seam sealer
Hi to all, I am restoring my 71 C-10 and I recently replaced the floor panels and inner rockers, I don't have a great welding machine and I could not completely seal weld the floor panels in. I have pin holes here and there. I went to the local auto paint supply and their cheapest seam sealer is around $20.00, and you need a $57.00 dollar caulking gun to apply it. I am wondering if I could just use Bondo to seal all the seams.
What do you guys think.
1971 C-10 2004 Yukon: 1998 Honda Accord 2008 Honda Civic 2004 HD V-Rod http://67-72chevytrucks.com/vboard/s...d.php?t=226458 |
Re: Bondo VS Seam sealer
i would not..that is the flex area. and it's just going to pop out and kill your 3000.00 paint job for 70.00. that caulk gun and seam searler rocks
Eastwood sells brushable seam sealer for around $20. that works super. BONDO is porous which means moisture will penetrate it especially when it cracks due to stress but even without cracks, water will penetrate unless you seal it with a good epoxy primer or other water sealing paint.
sufficiently talented fool
![]() Join Date: Jun 2006
Bondo is NOT waterproof. It will allow water in and let the rust begin.... You could use Mar-glass made by marson, it is like a fiberglass paste. We used mar glass on the inside of the cab, seam sealer on the underside, and a two part epoxy sealer in the drip rails.
"it's impossible to be surrounded by idiots when you are part of the circle" ![]() 2003 Suburban 2002 Pontiac Montana 1981 Corvette 1966 Impala Convertible Click here to support the board |
Next project: 1970 K10
The brush-on seam sealer from Eastwood works well, and they also have a tube of seam sealer that works in a regular old silicone/RTV type gun.
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
![]() Join Date: Jul 2006
3M has a general purpose seam sealer that will work in a regular caulking gun...Don't know the number of the top of my head but it comes in a blue and white tube... and it is like $16 a tube
Project Family Values Build Thread Vehicles/Projects: -1971 C10 SWB Fleetside! Gathering parts now, will begin frame-off resto soon... Pleasure in the job puts perfection in the work. -Aristotle |
I bought seam sealer at Carquest that actually came in an areosol can. Don't remember what I paid for it, but you bend the nozzel/tube and the seam sealer flows out. Pretty cool, just can't remember the brand.
04 4x4 GMC Ext. Cab lifted 71 2wd GMC / Ramjet 350 ready for sheet metal 49 Studebaker pickup |
Active Member
I have buddy that does a lot of insurance body repair. He has begun using a type of LIQUID NAIL called "FRP" that mimics the seam sealer. It even works as a sound deadner if you put it on and let it begin to set up then use a mortar trowel with the 1/4" notches to spread it. It comes in a gallon can and is off white in color.
He has a Harley Ford F250 in his shop with the cab completely stripped out. The factory sound deadner is painted on and troweled like tile mud too. All up on the fire wall and under the seats. The Liquid Nail stays flexible and doesn't stink once its set up. May be a hillbilly fix but its cheap. |
I just purchased some brushable seamsealer that is self leveling so you do not see the brush marks for $18.00 at a paint supply store and it works great.
Active Member
I agree go with the seam sealer and Cmars45000 is right 3m does make one. I have it in the shop and if we were'nt under a Tornado watch and it was'nt raining I would get the part # for you. We use a urethane seam sealer from IES at the body shop I work at and you do have to have a special gun for it, but not the 3M, I think it is called something like "Fast and Firm"?
'70 Chevy stepside, ECE discs & 4/6, '00 GMC ext. cab stepside, never ending project '07 GMC Crew Cab, 24's & 5/7 "We, the unwilling, led by the unquailified, have been doing the unbelievable for so long with so little, we now attempt, the impossible with nothing" |
Chief Honcho In Charge
Here's a goofy question...What is seam sealer used for (other that the obvious...to seal a seam?
Thanks, Tim
1992 1500 4x4 Shortbed 1984 Ford F250 Supercab Longbed 6.9L Diesel 1972 K10 Cheyenne Super Fleetside Short Bed - 350 - A/C 1971 VW SuperBeetle 1960 Wife 1984 Son 1986 Son 1989 Son Previous Trucks 1967 C10 SWB (1980-1981) 1971 C10 LWB (1998-2004) |
As for price of seam sealer that is way over priced for a tube of it. Go to an oreillys and buy it, like 9 bucks for the 3m stuff or I use transtar stuff which is cheaper. As for other uses for seam sealer I use it where bondo no good, ie drip rails, to blend rockers into the cab. Also here is a rigged use for it, did it in autobody class, used it as an adhesive to repair a 78 ford door panel. I use the seam sealer on stuff that will recive automotive paint and you will see. But when it comes to floors I use a hardware store paintable siliconized acrylic caulk. They got it any many colors, I use black alot, and it seams to bre alot easier to use than seam sealer. I have used liquid nails as a seam sealer to in the cowl area.
#13 |
Thanks for your help guys, I ordered some of this stuff from Por-15, it comes in a squeeze tube.
POR PATCH™ - Black [PPB] $17.25
1971 C-10 2004 Yukon: 1998 Honda Accord 2008 Honda Civic 2004 HD V-Rod http://67-72chevytrucks.com/vboard/s...d.php?t=226458 Last edited by JCA1972; 12-30-2006 at 12:35 PM. |
#14 |
So what is seam sealer? I know it seals a seam....but if you grind don't you have a smooth seam to paint?
