Old 12-29-2006, 08:33 PM   #1
msgross
msgross's Avatar
Superwinch hub question... lockouts have play in them
was messing with my superwinch hubs today and noticed that both of them have some outward movement in them (1/16th - 1/8th") is that normal? Other than that they operate fine. Took one apart and the movement is due to the snaprings not holding it tight to the inside of the hub. My Milemarkers dont have "play" in them. Should I swap them out or is there some kind of spacer that might be missing, or is this normal?
msgross is offline   Reply With Quote
Old 12-31-2006, 10:27 AM   #2
msgross
msgross's Avatar
Re: Superwinch hub question... loskouts have
ttt
Old 01-01-2007, 08:19 PM   #3
Zoomad75
K5Camper
Zoomad75's Avatar
My superwinch hubs have zero movement. Are you talking about the whole outer section or just the dial?
Rob Z.
1975 K5 350/465/205/D44/12b 4" lift on 35's- RIP
1991 K5 8.1L/NV4500/241/D44/14b FWC Camper
Zoomad75 is offline   Reply With Quote
Old 01-01-2007, 08:26 PM   #4
msgross
msgross's Avatar
the whole outer section "pulls out" just a bit. There is slack between the inner unit and the snap rings that allows play...both hubs do it the same...
Old 01-02-2007, 07:07 PM   #5
Zoomad75
K5Camper
Zoomad75's Avatar
Does your outer section have an o-ring seal on it? (it seals between the outer hub body and the tube portion of the hub assembly itself) Mine does and it seems like it's almost 1/8th of an inch. Might be why mine don't move.
Rob Z.
Old 01-02-2007, 07:31 PM   #6
msgross
msgross's Avatar
maybe not..i'll have to check it out...someone might have done a brake job at one time and left them off.... they work great other than the play. O rings would hold the inside parts up against the clip rings better...thanks.
Old 01-03-2007, 01:16 PM   #7
OLDCHEV4X4
OLDCHEV4X4's Avatar
mine didn't do that, but the directions that came with my hubs said it was ok to have in and out movement.
72 k/10 short wideside
72 k/5 Blazer
72 K/5 Blazer - obstacle course racer
72 custom/10 8' bed
70 K/5 Blazer
67 C-30 GMC Flat bed
86 GMC K2500 Plow Truck
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
72 Sears 12hp Tractor
Glenmoore, Pennsylvania
OLDCHEV4X4 is offline   Reply With Quote
Old 01-03-2007, 03:29 PM   #8
Burt4x4
Burt4x4's Avatar
On my Warns there is an Oring that seals the hub. I would guess that small amount of movement will not cause an issue other than alowing water in...possably.
I wouldn't worry too much about it.
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
