12-30-2006, 12:25 AM | #1 |
wheel bearing welded to spindle
Looks like I need a new spindle and bearing. The only kits I find are
drop kits. Where can I buy a stock kit for a 72' K5 4X4.
Joe Peters the HatGuy 72' K5 Highlander My Daily Driver http://www.pbhats.com/BLAZER/index.html |
12-30-2006, 01:44 AM | #2 |
huh ???
Re: wheel bearing welded to spindle
You'll probably have to goto a junkyard. Nice part is the Spindle should be the same up into the 70's as long as it's off a Dana 44 axle...
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's "I am a bomb technician. If you see me running try to keep up!" |
12-30-2006, 07:54 AM | #3 |
Thanks that is good news
How can I tell if its a Dana 44 axle ?
12-30-2006, 10:27 AM | #4 |
Member #1049
Here is a link to axle identification... You will find what you need under 1971 to about 1980 chevrolet 1/2 tons 4X4's... they used either a Dana 44's or a Corporate 10 bolts.. you need one for the Dana... Left or right sides are the same..
http://coloradok5.com/axleguide.shtml |
12-30-2006, 05:13 PM | #5 |
The LuvShack Garage
Neat link Rat
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Tow Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
12-30-2006, 05:29 PM | #6 |
pre '76 dana 44's had what was known as a small bearing spindle . after that dana enlarged the spindle and inner brearing , then in '78 gm 10 bolts carried on with the same spindle bearing setup
'70 k-10 longbox- mid 70's drivetrain 350/350 487x heads 10.1:1 flowmasters ,35's 3.73's auburn posi ,rear shackle flip. '72 short stepside U.S. forestry truck, '73 455 buick,400 turbo,dropped 2"-4 1/4" ,3.07 posi,:'89 silverado 1500 ,OK truck ,5.7 holley tbi ,trick 700r4 3.07 auburn posi ,and my '66 skylark ,'73 centurion and my '84 monte carlo imca stock car |
