12-30-2006, 02:54 AM | #1 |
Alright Alright Alright
door weather stripping question
im currently in the market for new weather stripping for my doors beacuse i can feel and hear the wind come through when im on the highway. what company out there make the cheapest product?
1972 Cheyenne Chevrolet red and white 357ci, Vortec heads, GM Performance high rise intake, Comp 268H .454/.454 218/218 110 LSA Quadrajet carb, Flowtech headers, 2.25 40 series HEI, Curve kit, TH 350, 3.07 gears 275/60/15s on 15x8 rallies |
12-30-2006, 03:22 AM | #2 |
Out of the carpool lane.
Re: door weather stripping question
Your local junkyard. They carry a wide range of Chevy trucks and vans that you can get great quality weatherstripping from. Just pull it and place it on your truck and cut to length. My pair were $5 total.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... |
12-30-2006, 08:27 AM | #3 |
Get them from an S10.......
1997 GMC Sierra Ext 1965 Mustang |
12-30-2006, 10:43 AM | #4 |
yep, junk yard , the GM products with the push on style weatherstripping, already broken in for ya, no glue/batteries needed
12-30-2006, 01:26 PM | #5 |
are yall talking about the kind of stripping that is the same shape as the door or the kind that just comes in a roll?
12-30-2006, 02:01 PM | #6 |
I got the cab kit from GMC Paul's that includes everything but the windshield strip.
I haven't installed it yet because I don't want to do it between rainstorms. It was the best looking kit out there and I have never had issues with orders from them. |
12-30-2006, 04:34 PM | #7 |
Fabricate till you "puke"
I used junkyard S-10 seals on my 69, & had to "adjust" the pinchweld to get the doors to shut properly, but 5 bucks was a damn decent deal! Now my Chevy is wearing a 4" chop top, & I actually trimmed the S -10 seals about 4" top fit......my guess is the seal will be a tad short on a stock top tho..... L
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
12-30-2006, 09:23 PM | #8 |
Got mine from LMC truck.They worked perfectly. Did have to use a few clothes pins to hold in place but they set up real nice and dont leak.
12-31-2006, 11:19 PM | #9 |
are these the shape of the door or are they in a roll? how do you secure it to the truck? do you use adhesive?
01-01-2007, 12:24 AM | #10 |
Rolled on Paint Club
I got the no-glue weather strip from GMCPaul. The package says it is for a late 70's to '93 Dodge Pick-up and it pressed on really well and works fine. Came in a long strip and there was about 6" extra that had to be cut off. At least it wasent made in China ( was from Brazil)
Bob
1970 GMC 1500 swb fleetside SB 355ci. Smog heads Summit 1102 cam Performer intake and carb. Finally in about 1 piece in the yard. |
01-01-2007, 12:29 AM | #11 |
I used the weather stripping from a 1991 GMC full size truck. It seems to have worked good so far but have not driven it since installation. I had to cut about 2 inches from it. It cost me 8.00 at the pick n pull yard. Should have waited until the 1/2 price days.
01-01-2007, 01:13 PM | #12 |
I used the weather stripping from the side sliding door of Astro vans. They seem to get less wear & tear because of there position and are often in real good condition. You get a couple feet extra from the big door, but you still have to find 2 to do both sides of a truck. If you go that rout there are 2 places that have a foam dowel inside the weather strip ( about 8 inches long by 1/2", you can feel it inside the strip ). That has to be removed or your door won't close, one can be removed when you cut the piece to get it out ( if the sliding door is still in place ), the other just pull out with needle nose plyers. There's tiny little holes in the stripping that you can pull the dowely pieces out through. I used a nail to get it started. Just another thing to look for at the junkyard for ya.
I got a bench seat baby, you don't have to sit over there. |
01-02-2007, 01:57 PM | #13 |
Bob d, do you have a link to the weather stripping your talking about?
01-02-2007, 07:59 PM | #14 |
01-06-2007, 07:23 AM | #15 |
steele in north carolina has em.
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
