12-30-2006, 05:43 PM | #1 |
Brake lines for disk/drum prop valve?
So I have the prop valve and the lines that run from the M/C to the valve. But the stock lines are 3/8 and mount to the bottom, where the new valve has one on the bottom (and it's 1/4") and one in the back. I have been to every parts store and nobody has a 3/8 to 1/4" reducer, or a male to male union so I can run a short line to the back.
Where can I get these parts? Did anyone else have these issues when swapping the front to discs? Man, what a pain! |
12-30-2006, 06:11 PM | #2 |
Re: Brake lines for disk/drum prop valve?
Maybe 70c10 (Jim) can chime in here on this. He went through the same problem last week......
1997 GMC Sierra Ext 1965 Mustang |
12-30-2006, 08:11 PM | #3 |
Active Member
I ran into the same thing and got the required reducers/adapters at my local NAPA store. They always come through with the right quality pieces.
Good Luck.
The older I get, the faster I was!! |
12-30-2006, 09:53 PM | #4 |
NAPA was the first place I went. I will go to the bigger NAPA tomorrow and see. I figured if anyone had it, it would be them, guess just not in my little town.
12-30-2006, 10:14 PM | #5 |
Designated A-hole!
Could one of y'all post pics of your setup, 'cuz I swear I think I have mine backwards.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
12-30-2006, 10:59 PM | #6 |
Front to front, rear to rear for 1/2 ton, reverse for 3/4 ton. There is a pic on here somewhere when I asked about hose routing.
12-30-2006, 11:02 PM | #7 |
Designated A-hole!
After doing a little reading, I think I'm gonna rob the booster/ m/c /prop valve off a 84 and put on mine, I hate the rusty, leaky m/c and ugly prop valve in the way on mine.
12-31-2006, 10:40 AM | #8 |
67-72 Addict!
Dave, I went to every parts store in town for the reducer fittings in the rear of the prop valve. I finally found it at Napa but I don't know the part number. I used two fittings (inverted flares) to make it work. The front line reducer fitting was easy to get. The brake conversion is on hold right now so I haven't been able to see if they will leak. I will post a pic of the fittings later today.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads Last edited by 70c10; 12-31-2006 at 10:40 AM. |
12-31-2006, 11:32 AM | #9 |
Keepin an eye out
I went through the same thing...so I ended up upgrading to stainless brake lines.
1970 Chevy C10 SWB 5.3 1996 Toyota Tacoma SR5 4x4 2007 Vespa GTS 250 Scooter ZIP 91351 |
12-31-2006, 04:50 PM | #10 | |
12-31-2006, 08:38 PM | #11 |
So I got it all connected, but the prop valve is nowhere near mounting like it's supposed to. The prop line and bracket kit I got was about 3/4" too wide where it mounts to the M/C. Then when I got that together, the rear line was too close to the booster. Man, what a mess.
I'm guessing I will be replacing it all very soon anyway, but I will bleed it tomorrow and see if it's at least functional. |
12-31-2006, 08:56 PM | #12 |
67-72 Addict!
Here is the pic showing the two fittings between the prop valve and existing brake line fitting. NAPA just started selling a new type of coated brake line that is bendable by hand . It's very nice and you can bend it like a pretzel without kinking it!
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads Last edited by 70c10; 12-31-2006 at 08:57 PM. |
12-31-2006, 10:30 PM | #13 |
Got mine at home depot in the plumbing section
12-31-2006, 10:34 PM | #14 |
After looking at the pic on GMC Paul's site, I noticed they are way different than the ones I got.
My guess is the ones I got are for a different year. I can't find the paperwork, so I'm not sure what they said they were for, but they sure are these. I was able to get the 3 fittings to connect the back, it's just wicked ghetto. I'll post a pic tomorrow. I am looking to replace everything soon anyway, but this should get me on the road. My bracket looks like the one above but my lines look like these: No wonder they didn't fit! Last edited by jimmydean; 12-31-2006 at 10:42 PM. |
