70 chevy c-10 6 to 5 wheel lug upgrade
I wanted to convert my 1970 chevy c-10 6 lug wheels to the 5 lug wheels.
I found a 72 fleetside w/ 5 lug but the rear axles have the leaf spring system, versus the rear coil springs that I have. Is this still possible to do without too much grief? thanks, dane |
Re: 70 chevy c-10 6 to 5 wheel lug upgrade
You need to measure the rear end of each truck (backing plate to backing plate) to determine if they are the same width.
Anything is possible, you will have to define what "too much grief" constitutes, including your mechanical skills, tools, and shop or work space.
ongoing 1970 c 10 lwb ![]() 1994 z-28 few mods.-owned since new ![]() 1978 vette silver/grey 25th anniv. paint ![]() |
67-72 parts collector,…
![]() Join Date: Nov 2002
Also Early Classic Enterprises sells 5-lug conversion axles for your 6-lug rearend,... if the leaf spring one doesn't work out. Check, www.earlyclassicenterprises.com
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 12-30-2006 at 09:50 PM. |
Fortunately, my 69 was converted from 6 to 5 lugs before I got it. But from all appearances the swap is (was) simple and the axles appear to me to be the stock length. If you need me to measure mine, let me know.
Mike
69 C-10 SWB Fleetside 454/TH400 (For Sale) http://67-72chevytrucks.com/vboard/c...ct=1299&cat=12 70 El Camino 454 TH700 29 Model A 4-DR Sedan Deluxe |
turbo enthusiast
lots of good info here
"But daddy, I didn't hit them all with a stick"...what my 6 year old tells me when I pick him up from school early for fighting ![]() |
if the rear ends are the same width you could just cut the spring perches off the new rearend and weld new ones on in the correct location.
not that big of a deal if you have a welder,space and time to do it. Frank
70 chevy lwb c10 454/th400 and a 9" rearend suicide doors, marker light fuel fill, 4" cowl , mini tub |
