Old 12-30-2006, 09:50 PM   #1
chipflyer
chipflyer's Avatar
NP 205 trans adapter question
Is there supposed to be a gasket between the transmission and the T case adapter on a NP205 with a turbo 350? Took mine apart today to replace the coupler seals and install a fresh built t case and noticed there was no gasket there before and it looks like it might have been leaking.
Anybody have any idea?
Jeff
I'm not a pessimist, I'm just optimistic that bad things are going to happen.
1971 Cheyenne Super K10 - tilt, cruise, air, am/fm, tow hooks, factory buckets!
1986 Jeep J10 pickup, - 5.3L Vortec with 4L60e and NP241.
chipflyer is offline   Reply With Quote
Old 12-30-2006, 09:52 PM   #2
1969k10stepside
Re: NP 205 trans adapter question
I believe there should be one
1969k10stepside is offline   Reply With Quote
Old 12-30-2006, 10:52 PM   #3
gator2511
gator2511's Avatar
I have a TH400 bolted to an Advance adapter and it has a gasket between the tcase and the tranny.
gator2511 is offline   Reply With Quote
Old 12-31-2006, 02:49 PM   #4
kwmech
There should be a square cut 'O' ring between the 2
Old 12-31-2006, 10:32 PM   #5
chipflyer
chipflyer's Avatar
I went back out and looked in the oil pan I had under the back end of the transmission and there it was, the square cut o ring! Now the next question is can that o ring be bought at a parts store or is it going to be hard to find?
Thanks guys
Jeff
Old 12-31-2006, 10:43 PM   #6
1969k10stepside
Should be easy to get one.Just tell them the tranny and t case and they should find one
