fuel tank ???
do the blazers and burbs use the same tank and sending unit or are they different?the truck is an 87 blazer but the parts dealer only lists one for a burb
Re: fuel tank ???
The burb tank might be bigger. Sending units should be the same. Blazer is 350 TBI fuel injection? In tank fuel pump in the Burb for TBI. If yours is carb, then it may be different. Tanks in Blazer are probably 25 gal. Burb is 30 gal. Mine is anyways.
If you can make the clearance then the burb tank should fit. Might have to adapt the tank straps.
2011 Chev Silverado LT 1500 4x4 Crew Cab 5.3l ![]() 2005 Toyota 4Runner family beater ...would have more but my yard ain't all that big... ..nothing like a Chevy fence all bought and paid for.. ...there's a few holes in it though... |
Re: fuel tank ???
The Blazer and Suburban shared a 31 Gallon tank whereas the Suburban used a 40 something gallon tank. I believe 87-91 is all the same on the tank because of the fuel injectio "baffles".
junk collector
Re: fuel tank ???
IIRC, the difference in the smaller tanks and the 40 gallon is in height. So if you have the correct straps, it should work. I think most burbs had 40 gallon tanks.
'87/89/76 K5 in progress '99 K2500 short crew '91 camaro rs '98 jeep tj '52 willys cj3a |
Professional Grade
Re: fuel tank ???
The 40 gallon tanks are the same depth as the 32 gallon tanks, same width as well, just longer than the smaller tanks.
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
Re: fuel tank ???
thanks guys.the 25 gallon tank and the 31 gallon tanks are the same width and length just a difference in depth.I masured out for thr 40 gallon unit but it would be way to tight in the back of a blazer.
or can i drop a fuel injection sending unit in my 82 tank? |
junk collector
Re: fuel tank ???
that it was slipped me up, the 25 and 31 are same except depth.
How much larger is the 40 gallon?
Re: fuel tank ???
the 40 gallon tank is 6" longer and wouldnot get around my hitch on the back of the blazer
| Bookmarks |
