Old 12-30-2006, 10:55 PM   #1
longhorn71
longhorn71's Avatar
tanks??
are the burb fuel tanks and blazer ones the same?or do the mount differently?
longhorn71 is offline   Reply With Quote
Old 12-30-2006, 10:58 PM   #2
Russell
Professional Grade
Russell's Avatar
Re: tanks??
Hey Dean!
Burb tanks are usually bigger, though I have seen a few K5s with the bigger tanks. They mount the same, but use different straps, and different crossmember spacing.
My 80 GMC is running a burb tank, but it is a longbox, and there are only inches to spare between the rear diff housing and the fuel tank when the springs are on the bump stops.
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 12-30-2006, 11:08 PM   #3
longhorn71
longhorn71's Avatar
Re: tanks??
dang i want to put the burb tank in the blazer to feed the 6.0 liter swap
might need to head to pick n pull with a tape measure
Old 12-31-2006, 12:48 AM   #4
Russell
Professional Grade
Russell's Avatar
Re: tanks??
It is just a matter of moving the front fuel tank crossmember back a few inches, diff clearance pending...
