Quick Question on Rear Coils?!
When I pulled my rear coils today I noticed that on one side, on the top "cup" the spring rests in, there was this thin rubber gasket thing that was all chewed up. Only there and not on the other side
![]() I was wondering if I needed to replace this part (if so, what's it called, where can I get it) or if it's fine to just go without them... thanks, Nate |
Re: Quick Question on Rear Coils?!
Never heard of that, mine doesn't have it. So, i would guess that you don't need it.
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
Truck Enthusiast
those are to help the springs from squeaking in the pocket
'85 swb |
so, if I went to pep boys to get some, what they be called?
Most fwd cars have those on the struts. They are to help prevent squaks from the metal on metal. They are call spring isolaters by most manufactures. I have had several 67-72 trucks and none of them have had them. If it's not squeaking I would not worry about it.
Seņor Member
an inner tube... cut an old one up and plop a piece of it in there if you really want. Otherwise, don't worry about it as most trucks don't have them in there.
