C-Notch Woes
Ok So I'm through day 4 of doing my notches and havent even cut the frame yet! I spent the first two days busting off all the rusted carriage bolts to pull my bed floor, and the next two busting off all these gigantic rivets...ok
So I go to line up my notches (CPP btw) and I notice that on my driver side notch, in the back, the 2 holes that line up with the holes from the panhard mount (left after you bang out the rivets) are different than the picture in the FAQ section. Lemme explain. The holes themselves line up correctly, but it appears my 64 has a different style panhard mounting point than the one in the FAQ section. So as far as I can see, I have to cut some out of my notch to clear the panhard mount and allow it to sit flush up against the frame. Not exactly "bolt-in." My question is...anyone else run into this? thanks, Nate |
LAIDOUT
Re: C-Notch Woes
Nate, got any picts of that interference? Not sure what is different on a 64 vs. my 71, but FWIW my CPP c-notches went without much trouble, but I did have to modify my Early Classics panhard bar setup when I installed some lowering blocks.
Re: C-Notch Woes
i dont have any pics yet, but i should in about a week when i go back to school and can get on my real computer...turns out the 64 had a slightly different framerail panhard mount>>only came that year...learned this over on chevytalk.com
Nate |
Re: C-Notch Woes
Hey BigSky, did you trim your spring plate before installing the notch? I was reading the install guide that Kevin wrote up and it looked like it was a must to fit flush. Yours looks great, btw.
#5 | |
Outlandish Trends - FL
Re: C-Notch Woes
I just opened the box w/ my KP step notches in them tonight when I got home from the Magic game so I'll be posting my CPP notches soon.
-Bret 67 short-fleet sold! Last edited by 67Fleet; 01-03-2007 at 12:21 AM. |
Re: C-Notch Woes
I bought mine when I got the rest of my stuff from CPP about 3 months ago. I just haven't cut into the frame because I miss driving it and it's taken too long as it is.
It will be about another month or two when I get the new upper arms and I will pull it apart and cut it up then. This rain sucks! |
LAIDOUT
Re: C-Notch Woes
Thanks, yep I cut that plate that was sticking out on the side.
LAIDOUT
Re: C-Notch Woes
Well it is Oregon...
