Old 12-31-2006, 11:32 AM   #1
Jaccoman
Jaccoman's Avatar
82 Trailering Special
I brought this Crewcab home with me as a souvenier of my Thanksgiving trip to NJ. On the way home, my 6yr old son named it "Rusty"
The PO removed the A/C set for his own rig, but it's otherwise complete.
The TH400 was locked up so I got a Transgo overhaul kit from Oregon Performance Transmission and pulled it:
An obvious leak from the valve covers, but while you're under there, you might as well check the pan gasket and rear main seal. Right?
... check compression, etc and we all know it's just a few more bolts to:
Right now, I'm waiting for delivery of the Fel-Pro gasket kit.
Old's Cool
Jaccoman is offline   Reply With Quote
Old 01-01-2007, 11:03 PM   #2
84 400
Sb 400 club
84 400's Avatar
Re: 82 Trailering Special
nice truck! what is the direction with it??
1984 chevy c10, built 400sb,.(SOLD)
77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363
1956 Willys Wagon (327 chevy) Project (Now Buick 225)
1980 Corvette L-48 4 speed
1992 Mustang GT built 5.0 5 speed
1985 C10 LWB Sold
1982 K10 SWB plow truck Parted out
1986 D30 M1028 fire brush truck Parted out
84 400 is offline   Reply With Quote
Old 01-02-2007, 11:53 AM   #3
68GMC454
THE VILLIAGE IDIOT
68GMC454's Avatar
nice truck...i have been hunting for a crew cab for yrs..but cant find one that is not completly rusted out..i guess one day i will find one...so what you gonna do with this one...
honestly honey,,i have no idea how that truck got here.
68GMC454 is offline   Reply With Quote
Old 01-06-2007, 01:12 AM   #4
Jaccoman
Jaccoman's Avatar
Thanks for the replies.
Right now, the plan is to get it running right and then do the typical body work (i.e. rockers, lower door skins) and use the truck as a stocker for home repairs, etc...
The interior plastic is in good shape, but the headliner needs help & dash pad is one of the worst I've seen. Also have to lose the saddle-blanket seat cover. I do think I'll need to pull the cap a shoot it to match the lighter cream color instead of the bright white it is now & change the grille.
Any input is welcome.
The TH400 ended up being unsalvageable. The reaction carrier on the output shaft had somehow welded itself to the internal center support. You can just about see the various colors of the drum from overheating in the image.
The ring that holds the pinion gears in that gear-train was also shattered.
Tomorrow morning, I'll be pulling another candidate from the junkyard to attempt to rebuild.
Old's Cool
