Old 12-31-2006, 12:17 PM   #1
Mechdawg
Mechdawg's Avatar
Truck keeps running?
Hey all hope the holidays were good to everyone I know they were to me. Anyhow Ive been out wrenchin on the truck and finally got it running again but now it dosnt want to stop. When I turn the ignition off it continues to idle normally for about another 10 seconds before shuting off. Any idea's? Im running a 327,HEI,electric cooling fan. It used to shutdown fine before the only new thing on the engine is the electric cooling fan.
Thanks all
Mechdawg is offline   Reply With Quote
Old 12-31-2006, 12:49 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Truck keeps running?
your electric cooling fan is back feeding into the HEI.
You should rewire it with a relay so it gets its power from the battery, and the signal to turn on from the switch... be it a toggle, a sensor, or both.
This will cure your run on issue, and make the fan run faster...PLUS, you won't melt your fuse box from the amps you are drawing from it right now.
Old 12-31-2006, 03:35 PM   #3
Mechdawg
Mechdawg's Avatar
I thought it might be something like that thanks so much for the help.
