12-31-2006, 02:35 PM | #1 |
What other 12 bolt rear ends will work?
Well I am going to have to narrow my rear end about 1 1/2 - 2" and i thought about what if there is another car or truck that has a 12 bolt that is a little more narrower than my trucks. Just hoping to get lucky. If there isn't any other ones and i am going to have to narrow my rearend about how much money would it cost to have it done?
Thanks Josh
(Project truck) 1970 C10 under complete transformation My current build thread http://67-72chevytrucks.com/vboard/s...d.php?t=212871 Other project: C5 corvette swap into 70 c10 http://67-72chevytrucks.com/vboard/s...=1#post2413517 On Hold |
12-31-2006, 02:44 PM | #2 |
Re: What other 12 bolt rear ends will work?
Maybe a Camaro or Chevelle. It might be cheaper to use a 9". How wide is your stock rearend?
12-31-2006, 02:48 PM | #3 |
Do you have the narrow 70 rear ? 68 / 69 and early 70 are about 1 1/2 in narrower . What's yours measure flange to flange ?
Can-Am Motorsports 37 Chev Coupe 331 4 speed 5.13 posi . ex-gasser . 64 Biscayne 409 2x4 4 speed 4.11 posi 65 Nova Wagon Drag Car 383 t400 (Dragin-Wagon) 68 c10 cst 396 t400 a/c buckets lwb 4.11 posi (SOLD) |
12-31-2006, 03:00 PM | #4 |
I will get that measurment today. Thanks Josh
12-31-2006, 10:29 PM | #5 |
From inside of the axel flange to inside of the other flange is just about 58". It was kind of hard to measure by myself so hopefully that is right. Thanks
Josh
01-01-2007, 03:55 AM | #6 | |||
Union Electrician
I went out to my garage and measured my rear in my 69 which is the original one, and it measured about 56 1/2" from backing plate to backing plate. If you measured to the backing plate(not sure what axle flange is) too then you have a 71-2 rear end and could benefit by finding a older 6 lug rear and converting it to 5 lug. I can go by my shop tomorrow and measure my 71-2 rar end I have in project Frank if you need me to.
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5" Help support the board->HERE Board vendors -> Vendors list Zip:40272 Big Sandy Survivor... Quote:
01-01-2007, 09:25 AM | #7 |
Ever think of switching to a (YIKES) FORD 8 or 9" rear? They are much more friendly to the builder in that you can set up the ring/pinion gears out of the housing so changing rear end gears is easy. They are strong. You can get a rear off an older Lincoln Versilles which is narrower, has disc brakes, can change over the spring-shock mountings and all you need to do is get the axles redrilled for your 5-6 bolt GM pattern. In a long run, you will be better off---. Yea I know--it's a ford but tell that to the thousands of guys who run street rods, drag race, etc. A ford rear is a what GM should have built!
01-01-2007, 12:36 PM | #8 |
The only thing that sucks for Josh is he already had the axles redrilled and bought brakes for this rearend. I believe the pass car 12 bolts use a smaller bearing so the brakets for the brakes won't work. With the 9" you can buy new axles with the right bolt pattern in whatever width you need for a decent price. Josh I have a few 9" housings and a couple third members. If you need one of them it's yours. I think in my stash up north I have a 3rd member with a locker in it too.
01-01-2007, 12:59 PM | #9 | |
01-01-2007, 01:17 PM | #10 | |
01-01-2007, 01:23 PM | #11 | |
Josh
01-01-2007, 03:06 PM | #12 | |
I think the 9" would be the easiest way to go but remember.... not all disc brake 9" rears are equal. Some of the Lincoln Versallies (sp?) rears had troublesome rear brake hardware that's not readily availible for replacement. A 9" that uses later Explorer rear disc stuff would be a good investment. Check Currie Enterprises to see what they offer brake-wise w/their rear ends. They would be the hot ticket for what brake parts to get.... not to purchase the whole rear end from for anyone on a 'budget'. Put the bed on & get it square w/the frame so you can get accurate measurements on the housing width you need. Good luck.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 01-01-2007 at 03:09 PM. |
