Old 12-31-2006, 04:20 PM   #1
Boise69
The Hammer Man
Boise69's Avatar
headers and exhaust time - what do you think of this?
http://cgi.ebay.com/ebaymotors/ws/eB...DME:B:EF:US:11
I dont know if i did that link will work right but its for headers on ebay that look like they will fit my 69.
- Has anyone used these?
- Will they work as well as advertised?
- For that shine and reliability is ceramic or SS a better way to go?
Boise69. Bought in Boise ID and its a '69
___________________________________________
1969 Chevy C-10 SWB 350/400 - drivable project
www.americanhammer.com
2013 MBZ Sprinter customized
2005 MBZ Sprinter Van
2004 Land Rover Discovery
2001 Yamaha Road Star
1997 MBZ E420
1989 Ferrari Mondial T
Boise69 is offline   Reply With Quote
Old 12-31-2006, 04:27 PM   #2
bodyman9174
Re: headers and exhaust time - what do you think of this?
that link is not working for me. never mind it is now sorry
bodyman9174 is offline   Reply With Quote
Old 12-31-2006, 05:13 PM   #3
gator2511
gator2511's Avatar
For about $75.00 more you can get a set of Hedman's ceramic coated with a 3/8 thick flange. I'm not a fan of the 1/4 inch flanges. Probably be ok with a fairly stock engine though.
gator2511 is offline   Reply With Quote
Old 01-01-2007, 09:37 PM   #4
Boise69
The Hammer Man
Boise69's Avatar
where can i purchase the pre maid pipes for my entire exhaust? I think i will be going with the 40 dyna flows
1997 MBZ E420
Old 01-01-2007, 09:45 PM   #5
Boise69
The Hammer Man
Boise69's Avatar
and ... since the bed has to come off anyway for paint, should i remove it early to do my new exhaust or is it just as easy to do it from below? I want to keep driving it so i have to replace the rusted pipes now.
1997 MBZ E420
Old 01-01-2007, 09:56 PM   #6
1968SWBBigBlock
Active Member
1968SWBBigBlock's Avatar
I am a huge fan of having a local shop that can bend pipe to make my exhaust for me. The cost is normally no more, often less. You will have a system that is many times better than you can do at home. Again the key is to find a shop that bends most if not all of thier own tubes, not a midas or tuffy style store.
1968 SWB
454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts
781 heads Ported with 2.19/1.88 SSTvalves
Lunati 60204 cam, Micro Trol lifters,
Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition
Holley 770 Street Avenger carb,Headers armor coated
Built by Watson Ruppel Performance in Sarahsville Ohio.
Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall
12 Bolt Eaton Posi 4.10 Richmond Gears moser axles
18.5" x 31" Hoosier Pro Street Radials
ET Classic 5 Wheels - polished
Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone)
Custom Paint & Body Work
Special thanks to my wife, my son and my money tree
1968SWBBigBlock is offline   Reply With Quote
Old 01-01-2007, 10:58 PM   #7
LockDoc
The Older Generation
LockDoc's Avatar
[QUOTE=Boise69;1965226
- For that shine and reliability is ceramic or SS a better way to go?[/QUOTE]
Do a search on stainless headers. There was a post about them becoming brittle after heating & cooling a few times.....
LockDoc
Leon
Old 01-01-2007, 11:17 PM   #8
bryanw1968
bryanw1968's Avatar
LockDoc
I've seen SS headers "blue" after getting hot several times. I know that Doug Thorley headers are nickel plated and won't do that. I run the Hedman elite 3/8" flange and they are coated in a silver paint looking color.
I like them a lot.
bryanw1968 is offline   Reply With Quote
Old 01-01-2007, 11:27 PM   #9
jimmydean
jimmydean's Avatar
The quote I got for my pipes from headers back was $225 with mufflers and I will be running 3/4 length headers (they are a little more work for pipes) at a shop down the street.
Just call around, it shouldn't be more than $200 if you have the mufflers.
jimmydean is offline   Reply With Quote
Old 01-01-2007, 11:36 PM   #10
st1x10
st1x10's Avatar
hey jimmy what headers are you running. I was looking for some 3/4 length headers, thanks.
1970 Chevy C10 "Under Construction"
2002 Chevy S10 V6
st1x10 is offline   Reply With Quote
Old 01-01-2007, 11:37 PM   #11
al's71gmc
4 eyed fever
al's71gmc's Avatar
Recently got cat back from a shop, 2 1/2 inch with flowmasters for $480. At that shop the flows were $220 for the pair. So I'd guess about $260 without the mufflers. Some shops won't use your parts tho...
Edit- $225 with mufflers sounds awful cheap. Was that for single or duals? The shops I called wanted about $330 with no name turbos for 2 1/2 duals.
1971 GMC 2500 4x4
1972 GMC Sierra Grande 1/2 t 4x4-#1 son's truck. Recently completed resto.
4 YO daughter," Daddy, I like your truck better than Mom's." (2000 F350-ranch truck) Smart kid!!
al's71gmc is offline   Reply With Quote
Old 01-01-2007, 11:57 PM   #12
jimmydean
jimmydean's Avatar
I am looking at the Camaro 3/4 ebay setup offered by White Performance for $145.
al's71gmc: My pipes are wicked easy because it's nearly a straight pipe the the mufflers, then a 45 degree dump straight down. It's only about 10' of 2.5" pipe, 2 mufflers (no name turbos) and 2 45 degree turn downs. It's a couple bends, but should be easy enough to do. It was $255 to run it out before the back tires. I would be cheaper if I decide to go with the Summit welded mufflers, I just don't know if I will or not.
Old 01-02-2007, 02:01 AM   #13
FarmTruk
In Memoriam...
FarmTruk's Avatar
I have no experience with these particular headers. But, they don't seem to be "extremely heavy duty" as advertised. 1/4" flange is a MIN. thickness you want for a street motor. 5/16" or 3/8" is better. Also, the 1-1/2" dia. primaries is a bit on the smallish size for anything other than pure stock.
The ceramic coat is a plus, as it is very durable, but the better set-ups also have ceramic coating INSIDE the tubes as well. Do these? Maybe so...but the seller makes no mention.
Also, what is the guage of the primary tubes? I'd say 16 ga. should be min. for heavy-duty. Again, no claim. Maybe they are. FYI, the Hedman Elites mentioned above are 14 ga.
Also would like to get a look at the flange/tube connection. The White Performance units, linked above by Jimmydean, do make a good claim of the sealing ability of their units with the laser-cut flanges. But would those fit a truck. They claim they are for a car.
IMHO, these are probably OK for a stock motor, and would certainly dress up a tired looking engine compartment. The fit is probably pretty good also, as the seller describes them as truck headers, not car headers. But there are some questions (above) that I'd ask B4 sending my $$.
'68 C10 SWB 307ci 2BBL
FarmTruk Pics Here
"You know, doing what is right is easy. The problem is knowing what is right."
FarmTruk is offline   Reply With Quote
Old 01-02-2007, 04:27 AM   #14
projectking
projectking's Avatar
bought those from fatrodder but the black ones. had to clearance them w/a torch and ball peen. they are too low for air bags aswell.
68 GMC C3500 Longhorn DRW
67 Chevy C10 LWB
90 Mustang Gt
90 Mustang Notchback
projectking is offline   Reply With Quote
Old 01-02-2007, 04:28 AM   #15
projectking
i can take pics soon of how i fit em if anyone is interested.
67 Chevy C10 LWB
90 Mustang Gt
Old 01-02-2007, 10:35 AM   #16
70c10
67-72 Addict!
70c10's Avatar
jimmydean- I'm pretty sure board member byrd bought those headers from Skip White and said they will NOT fit our trucks!. Check with him before you buy.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 01-02-2007, 12:00 PM   #17
byrd
Union Electrician
byrd's Avatar
Jimmy , Those headers WILL NOT WORK, unless you are making your own motor mounts I bought them and the PS fits like a glove almost too tight and the DS won't even go on, they interfere with the motor stands, by about 1 1/2"
http://cgi.ebay.com/ebaymotors/ws/eB...0124133&rd=1,1
Those are for the 88-95 Chevy truck and they fit great, but need a little clearence on the top of the DS frame rail, check out the last page in my build thread in my sig and see what was done to make them fit. They were cost effective too boot at $172 shipped for a ceramic coated header. They also come with an O2 bung that is plugged off if you decide later to do fuel injection. I am not sure if I can keep them inside the rails because the DS does come down a little further, but then again they will not interfere with the tranny linkage where as the camaro headers will. Just my .02...Randy
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5"
Help support the board->HERE
Board vendors -> Vendors list
Zip:40272
Big Sandy Survivor...
We cannot choose the way we die, but we can choose the way we live
If you can't fix it with a hammer, you've got an electrical problem.
I think Congressmen should wear uniforms like NASCAR drivers so we could identify their corporate sponsors
byrd is offline   Reply With Quote
Old 01-02-2007, 03:00 PM   #18
bryanw1968
bryanw1968's Avatar
Here is a pic of my 3/4 length elites....
Old 01-02-2007, 05:45 PM   #19
Boise69
The Hammer Man
Boise69's Avatar
I like them a lot.
Bryan,
Where did you get your Thorley's and what kind of deal did you get? Did they need any mdifying for them to fit?
1997 MBZ E420
Old 01-02-2007, 07:40 PM   #20
jimmydean
jimmydean's Avatar
Thanks a lot Randy. I thought these were the ones that DID fit, good thing I didn't drop the coin yet. I will be ordering the ones you pointed out in a week and go from there.
Old 01-02-2007, 10:39 PM   #21
FarmTruk
In Memoriam...
FarmTruk's Avatar
FYI...here is a good link explaining the "ceramic coat process" and benefits.
http://www.customclassictrucks.com/t..._coating_tech/
FarmTruk Pics Here
Old 01-02-2007, 11:36 PM   #22
jimmydean
jimmydean's Avatar
I have a special powdercoating that isn't as good as ceramic, but is very close and it's easy to use. The main goal of the powder is heat loss and it is good to 1700 degrees (cures at 400).
The company I got the powder from offers a ceramic coating too, but without the polishing process, it's not much better than the powder. The only thing about the powder is it comes in flat black only. Not that I mind, but some people like shinny stuff.
Old 01-03-2007, 12:11 AM   #23
byrd
Union Electrician
byrd's Avatar
YVW, I wish I would have known before I will be putting my set up on ebay soon I really like the way the front tube on the 88-95 come kinda of up a little and then back down, giving the space to run the plug wires under the headers to minimize their heat exposure and imo a cleaner look too Also they arefurther away from the starter on PS side with more room to get at the starter if the need arises.
Zip:40272
