Slowly getting CRSS...
Went to the Dyno Today...
It was and wasnt what i was expecting
But on top of my alignment being wack my engine is now burning oil i hope it just a not sealed intake or at worst valve guides. But i am definately investing in electric fans aluminum heads, bigger carb, and bigger cam. My truck was dyno'd at Ramsey's Performance here in Tampa. ![]()
-Nic Lutz, Fl My Team Website The Heavy Chevy Website ------------------
There is No replacement for Displacement... "If everything seems under control, you're just not going fast enough." - Mario Andretti |
67-72 Addict!
WHICH TRUCK OF YOURS DID YOU DYNO?
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
the 72 w/ the 454...
67-72 Addict!
iS THIS MOTOR STOCK? AND IF YOU DON'T MIND ME ASKING, HOW MUCH DID THEY CHARGE?
computer illiterate
is that rear wheel or at the flywheel?
72 2wd blazer 72 swb 4x4 |
it is at the real wheel
it was $60 for the 3 runs got alum intake edel carb comp cam headers everything else is stock
Post Whore
![]() Join Date: Feb 2000
That's not bad. Would be worth it after making mods to see what it did for you. What type of numbers were you expecting and what are you shooting for?
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
