Old 12-31-2006, 05:03 PM   #1
69TowRig
Watt Did U Get Dun This Weekin?
I know it's early since most of us have a three day weekend, but I am so happy about what I accomplished that I couldn't wait until tomorrow or Tuesday.
I installed my Early Classic Hidden Hitch Receiver yesterday afternoon, evening, night, and early this morning (I finished at 4:15AM).
The frame on my K5 has probably seen 3 hitches in the past, the frame ends were swiss-cheesed, split, and had stuff welded all over them. I spent quite a bit of time cutting stuff off and cleaning it up, then welded 2" angle gussets to the frame ends to support the hitch receiver.
I still have to pull it back off so I can remove the bumper brackets that some PO had WELDED to the frame. Why people do crap like this I won't know. I cannot install the last two bolts closest to the frame ends until I do this.
So without any more delay, here are the pics of what I started, worked on, and finished with last night. The hitch receiver has been sitting in the back of the Blazer since Spring 2005...
Frame condition (poor):
Gusset Plates I added:
-Chris
Building a stripper, one part at a time: 1969 K5, 307, 3spd, 3 seats, hard top. Added Pwr Discs, Pwr Steering, Aux Battery, T-case Skid, Lighted Sidemarkers, HEI, Lock-Right Diff, ECE Class IV Hitch, 32" MT/Rs. Parts to Install: Hand Throttle, Console, Tow Hooks, Dual Horns, AM-FM, Dealer Swing-Away Tire Carrier, Gas Tank Skid.
Also building a 1950 Willys CJ-3A and off-roading a 2001 Nissan Frontier on 1-Ton Portals...
69TowRig is offline   Reply With Quote
Old 12-31-2006, 05:04 PM   #2
69TowRig
Re: Watt Did U Get Dun This Weekin?
Cleaned off frame:
Removed old drawbar support:
*Almost* completed installation:
-Chris
Old 12-31-2006, 05:04 PM   #3
69TowRig
Also had to notch the corners of the fuel tank to make sure it cleared the rear of the hitch mounts:
-Chris
Old 01-01-2007, 08:03 AM   #4
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Not as much as you, but I found 2 of my air leaks, removed my front bumper
to get at one of them, still trying to figure out how to tighten up the other.
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Big Piggy: "Goliath" 07 Kodiak C4500
Lil Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 01-01-2007, 01:38 PM   #5
red71cheyenne
Back in the sticks
red71cheyenne's Avatar
Lets see, kind of same as you, removed gas tank to find out why sender isn't working, its shot. Reinstalled tank, and installed freshly painted brackets and rock guards and bumper. Installed and cleaned up the grill, fender skirts and tried to get my windshield frame square with the body. Still not having much luck with that. I've got about an inch and a half difference between drivers side and passenger side. Not good. Other than that, not much.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection
1969 K5 Blazer w/Tuned Port
2010 2SS/RS Flaming Orange Camaro
2011 K1500 Suburban
2014 K1500 Pickup
2008 Nissan Altima? The wifes' hoopty
red71cheyenne is offline   Reply With Quote
Old 01-01-2007, 11:03 PM   #6
69TowRig
Today I pulled the front crossmember, antisway bar, and leaf spring plates from an '88 Sub 4x4. Okay, maybe "pulled" wasn't the word. I cut off all the rivets, unbolted a ton of crap (thank God the front clip was already removed, as was the engine), then beat the rivets out and wrestled the thing out from under the truck, in the rain.
-Chris
Old 01-02-2007, 03:23 PM   #7
Chris27
Blazerless
Chris27's Avatar
I installed the remote start I got for Christmas. Now I don't have to go outside to start my truck to warm it up, just hit a button on the remote.
72' K5 Blazer 4x4 350TBI/700R4/NP205 3/4 ton diffs. Daily driver. SOLD
69' Beaumont 388/700R4 11.70@116
77' Bronco, Wife's mall cruiser/poser 4x4. Capable but too pretty to go offroad.
Chris27 is offline   Reply With Quote
Old 01-02-2007, 04:00 PM   #8
69TowRig
My brother has had those on his last two or three vehicles. Loves them.
-Chris
Old 01-02-2007, 06:44 PM   #9
Critter
Future TOTM Winner
Critter's Avatar
I gave my old body mount bolts 3 good soakings with penetrating oil! I hope to take the next step and pick up a wrench sometime this week.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces)
72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts
2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver
Check it out www.lsdyno.com
Critter is offline   Reply With Quote
Old 01-02-2007, 06:56 PM   #10
Kurt L
Kurt L's Avatar
i adjusted brake driver side, [pass side was done earlier] bled all the brakes on my burb then took it for a ride.sure was fun to drive it again.
Kurt L is offline   Reply With Quote
Old 01-02-2007, 06:56 PM   #11
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Degree of difficulty
Old 01-02-2007, 07:19 PM   #12
Chris27
Blazerless
Chris27's Avatar
Not bad, took me about 3 hours. Requires EFI though. Mine's pretty simple, no power locks, no alarm. Only used about 8 wires out about 30 that come with it. Basically, power, ground, tach signal (so it knows if it started), starter wire, ignition wire, accessory power (heater), hood pin switch, antenna. That's about it.
Old 01-02-2007, 07:38 PM   #13
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
No EFI here, oh well maybe next year
Old 01-02-2007, 08:43 PM   #14
69TowRig
With a little ingenuity I don't see why someone could not do it with a carb too. A relay setup with a small solenoid to kick the throttle open to close the choke when it kicks in should do it on a truck with strong engine and a hot spark.
-Chris
Old 01-02-2007, 09:25 PM   #15
red71cheyenne
Back in the sticks
I have one on the suburban and it works fine. I think it would work just as well for a well adjusted carb too. Automatic is kind of a must though, but I think you could bypass the clutch thing if you dared to leave it in neutral. Jeff.
2011 K1500 Suburban
2014 K1500 Pickup
Old 01-03-2007, 12:20 AM   #16
Chris27
Blazerless
Chris27's Avatar
My girlfriend has one in her Jeep. It's a stick. Just make sure your parking brake works
