Old 12-31-2006, 05:57 PM   #1
71MUTT
Can't ReMember
71MUTT's Avatar
tranny mount problem
Well, I need to say that I am a terrible mechanic. I can do the basics on my truck and have for years, like starters, water pumps, fuel pumps, alternaters, points and plugs, carrier bearings, universals ect... Done all these multiple times on me 71 C-10 LWB. Never pulled an engine or tranny before.
Lately I've been feeling a shimmy or vibration on low speed acceleration. So I'm under the truck looking around and I see that the tranny mount bolt is loose. So I tighten it, go to the otherside to tighten that one and it's missing. So I match up the bolts, spend a hour trying to line up the hole, then finally get it started. Tighten it. Tighten the existing one. Go back to give the one that was missing one extra pull and.....................stripped. Dam, was I pissed. Here a pic of the bolt. What did I ruin in the tranny and what should I do. Just having the one bolt tight seems to have solved the problem, but would like to have both bolts. Sorry about all the dirt and grime. This tranny has 250,000 miles on it and has never been worked on. (Or cleaned )
Adversity doesn't test your character; it reveals it.
71 C-10 LWB 350/TH350. I purchased it in 1978 for $1400. I'm currently abusing it daily. (when it's running )
71MUTT is offline   Reply With Quote
Old 12-31-2006, 07:02 PM   #2
poorboy
poorboy's Avatar
Re: tranny mount problem
You can pull the crossmembe and heli-coil the hole.
poorboy is offline   Reply With Quote
Old 12-31-2006, 07:21 PM   #3
rage'nrat638
rage'nrat638's Avatar
wow now thats a lot of dirt..you could always put a ratchet strap around the trans and cross member and tighten it up and cut the long end off j/k
heli-coil as mentioned .... are we talking about the two screws that we can't see. or the one we can see.
if your talking about the two we can't see..just replace the transmission mount about 12.00..if your talking about the screw's in the transmission case itself then heli-coil
rage'nrat638 is offline   Reply With Quote
Old 12-31-2006, 07:30 PM   #4
71MUTT
Can't ReMember
71MUTT's Avatar
35 years worth. I promise that within the next couple of years I'll get this truck right. You should have seen it before I scraped it.
I'll do a search on heli-coil and see what you guys are talkin about.
Old 12-31-2006, 07:40 PM   #5
krue
Designated A-hole!
krue's Avatar
Also known as a thread insert. It looks like a spring, basically you drill and tap the hole out larger, screw the "helicoil" in and it acts as new threads.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 12-31-2006, 07:42 PM   #6
krue
Designated A-hole!
krue's Avatar
Here's a link.
http://www.emhart.com/products/helic...FQFcgQodw2X2NA
You should be able to find what you need at your local parts store (may have to go to Napa, but I'm pretty sure I bought my last at Oreilly's.)
www.daveramsey.com
Old 12-31-2006, 07:58 PM   #7
71MUTT
Can't ReMember
71MUTT's Avatar
That was the exact one I was looking at with a google search. I was wondering if you could get it at the parts store? I'll look online. Will that area of the tranny handle the heli-coil insert. When I pulled the bolt out there was an aluminum type metal stuck in the threads. It probably wasn't aluminum, but it sure looked light.
Thanks.
Old 12-31-2006, 08:04 PM   #8
rage'nrat638
YUP THATS JUST THE OLD THREADS,,,
you may need to get what they call a bottom out tap. to tap the hole if its not open ended (blind hole)..most taps have a pointed end. those work when you can see thru the hold.. if it's a blind hole the bottom out tap has a flat bottom so you can tap the hole all the way to the bottom
Old 12-31-2006, 08:15 PM   #9
71MUTT
Can't ReMember
71MUTT's Avatar
Ya, I'm sure it will need a bottom out tap. Good to know.
