Old 12-31-2006, 08:49 PM   #1
solidaxel
solidaxel's Avatar
ECI or CPP or TCI Brakes
I am in the process of ordering a power master brake set up for my 53 chevy.
Any comments on ECI bracket master cylinder and booster as compared with CPP or TCI. Is one better than the other = cost vs ease of installation.
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 01-05-2007, 05:09 PM   #2
solidaxel
solidaxel's Avatar
Re: ECI or CPP or TCI Brakes
I guess I will check them all out and hope someone comes up with some suggestions!!
LS 3 4L70E
Old 01-06-2007, 08:48 AM   #3
pgf545
pgf545's Avatar
Dang Solid no responses???? Well I don't know anything about these guys, but I was looking at going with Master Power Brakes. I have bought a couple of items from CPP and mostly everything worked. The fuel tank needed a mod to clear the springs and I still need to do a little work to get the mounting brackets to work. I did call them and felt like they didn't want to help or maybe they had never run into the problem that I was having. I wouldn't go as far as saying they had bad customer service because the guy was nice and tried to help, but he was going to check with someone else and call back. I still haven't heard from them so I just did what needed to be done to fix it. I would probably get more stuff from them. This was my experience from them.
Bernie
52 Chevy Truck (Dad's)
http://67-72chevytrucks.com/vboard/s...d.php?t=206021
pgf545 is offline   Reply With Quote
Old 01-06-2007, 10:04 AM   #4
solidaxel
solidaxel's Avatar
I used ECI for there M/C & mount for a dual M/C and it worked as he said it would. When I called him to ask him about his set up he does not use a porportioning valve but instead a metering valve. He stated because of the rear tire size (Larger) on hot rods you only use a metering valve on the front.
Makes sense, and he did not hesitate to tell me why, and also said to call him back when I had my decision made on the front brakes. The reason is all the aftermarket companys use different calipers and he would size the Master cylinder to which ever caliper I was going to use. So lets see if I get the same answer twice !!!!
LS 3 4L70E
Old 01-06-2007, 02:46 PM   #5
pgf545
pgf545's Avatar
Let me know because I will be needing a booster and M/C soon.
Dumb question...who is ECI?
Bernie
Old 01-27-2007, 03:22 AM   #6
solidaxel
solidaxel's Avatar
Sorry I did not see your question!
ECI is Engineering Eomponents Inc.
ecihotrodbrakes.com
LS 3 4L70E
Old 01-27-2007, 03:23 AM   #7
solidaxel
solidaxel's Avatar
Lets try that again
ENGINEERED COMPONENTS INC.
LS 3 4L70E
Old 01-27-2007, 08:19 AM   #8
MARTINSR
MARTINSR's Avatar
Solid, you ARE running a solid dropped axle?
Brian
1948 Chevy pickup
Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats!
Bought with paper route money in 1973 when I was 15.
"Fan of most anything that moves human beings"
MARTINSR is offline   Reply With Quote
Old 01-27-2007, 10:15 AM   #9
solidaxel
solidaxel's Avatar
The Solid axle comes from a term that is used on Corvettes. I have a Swing Axle 65 and a Solid Axle 62 ,and when I was selling things on evil bay I used Solidaxle for my handle but it was takes so I changed the spelling solidaxel.
Both of my pick ups will have IFS the 55 has a Mustang ll type and the 53 that I am building now has a Dodge Dakota IFS
LS 3 4L70E
Old 01-29-2007, 11:30 PM   #10
MARTINSR
MARTINSR's Avatar
I have it, thanks. Nice rides!
Brian
1948 Chevy pickup
