Old 12-31-2006, 09:23 PM   #1
lt1CJ
Angry neutral saftey switch wiring/ van tilt
Hey I'm new here and I must say this is a great site! Quick question, I picked up a 72 shortbox 4x4, it was originally a 4 speed standard. Previous owner installed a th350/ np205, auto pedals and an auto van tilt coluum.The truck is not complete and not running at this time. I can see the neutral saftey switch which I know needs to be relocated, but there are no wires for the switch coming from the fuse block because this truck was a standard originally. Any idea how i can wire the switch and back up lights? Is there some sort of wiring for a clutch saftey switch on the standard tranny trucks I could use? Ive got the the factory assembly manual but cant find anything. You think after all these years someone would have numbered, put the pages in order and added an index in the manual. Thanks for the help guys!
lt1CJ is offline   Reply With Quote
Old 12-31-2006, 09:39 PM   #2
centsless
sufficiently talented fool
centsless's Avatar
Re: neutral saftey switch wiring/ van tilt
Welcome to the board!!
Locate the starter wire from the ignition switch(purple, I think) and cut it. Hook both sides of that wire to the switch. Locate the OE reverse light wiring, and hook the wires(2) to the rev. light switch on the column. Someone else will probably chime in with a link to the wiring diagrams.
"it's impossible to be surrounded by idiots when you are part of the circle"
2003 Suburban
2002 Pontiac Montana
1981 Corvette
1966 Impala Convertible
Click here to support the board
centsless is offline   Reply With Quote
Old 12-31-2006, 09:45 PM   #3
john
member #16
john's Avatar
This thread will get you going in the right direction.
http://67-72chevytrucks.com/vboard/s...d.php?t=147927
john is offline   Reply With Quote
Old 12-31-2006, 10:31 PM   #4
lt1CJ
You guys are great! Thanks alot, those links solved my problem. Happy New year!
Old 01-01-2007, 02:37 PM   #5
krue
Designated A-hole!
krue's Avatar
Welcome to the board from South Mississippi!
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 01-01-2007, 03:56 PM   #6
Fastfun
Fastfun's Avatar
Welcome from Scottsdale
Fastfun is offline   Reply With Quote
