another dumb idea?
my 68 has the side makers that are just reflectors not lights. i am considering using the front openings to feed a dual snorkel air cleaner. do you think the 2 1/2 x 5 1/4 openings are large enough to feed a 750 cfm carb? i will make my own bezels and try to work the molds so they direct air stream in. i worry that they may allow the airstream to suck air away from the engine. thanks, pkj
Re: another dumb idea?
i think you'd get little or no ramair flow effect from the side of the fender
With air rushing past the side you'd probably get a vacume effect. But if you got a couple of those scoopy things like the covers for a dryer vent from a house and duct taped them on ....................
I got a bench seat baby, you don't have to sit over there. |
NOT REALLY BANNED!
![]() Join Date: Jul 2004
Just use your marker lights in your grille.
1987 Mustang Coupe - 2.7 Stroker, 78mm turbo, Stainless header, 3" Exh, FMIC, 160lb/hr Injectors, MS3, twin walbro 255's, 34psi. Eating V8's daily. 04 Pontiac GTO 04 Ford Mustang GT 68 C20 LWB stripper truck 73 K5 Cheyenne 76 C20 Sierra Crew SRW 88 K20 Suburban I'm not hammering on metal just to hammer, i'm creating a piece of art. |
you are right, there would be no ram air effect, but it would be fresh air instead of hot engine air. i want to keep front lights functioning. pkj
its all about the +6 inches
a cowl intake would be way better
well yea, but i already bought the hood so that wont work. so general vote here is dont use side marker openings for fresh air? thanks, pkj
nope, not a cowl induction hood.... a true cowl intake system. I'm searching for an online link or photos... NASCAR used it back in the day, it actually works better than most of the BS cold air kits on the market today.
If anyone knows what I'm talkin about and has a photo or link, feel free to jump in. There was a company that used to advertise in the back of Hot Rod with this kind of product... ![]() |
nascar racecars are still using the forced air cowl intake systems//they're real basic to engineer pictures are in most all racing related magiznes
Here is a photo of what i was talking about. See how the firewall is acut to where fresh air can feed the air filter via ducting...
![]() Here's another example ![]() While http://www.ramairbox.com/ has a great product, this is nothing you couldn't fab up yourself if you really wanted it. |
![]() Join Date: Feb 2004
Hey, I wonder just how much air one of those things would deliver in our trucks.
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!" |
Yep, you'll get nothing much from the fenders. The base of the windshield is a great place to get air from.
Those two pics are a great idea...
Kelly '05 GMC Sierra SLE Z71 Bone stock except for new bed rail caps. |
#13 |
with the barn door aerodynamics of our trucks, there would be a LOT of air to be had. The more aerodynamic a vehicle is, the less pressure there would be there. That is a high pressure area once the truck is at speed.
#14 |
longhorn man that looks good. if i follow right the air recieved will be drawn from the windshield cowl? i already built one dual snorkel that both snorkels point straight forward. i could turn it around and fit to firewall. i cant get this at work puter to let me post pics. i can e-mail them if someone can post. sure glad i asked befor i started making molds for parts. thanks, pkj
#15 |
If this is a daily driver, you'll want to make the openings up high in the cowl area to avoid water draining into the air filter... bad things would happen then... but otherwise, it's a fine idea.
In all reality, these trucks have enough frontal area with such a tall grill, that you could do something simple like this; ![]() And get great results. |
#16 |
okay. since my truck is apart how much room is there between top of core support and bottom of hood. i can make all that stuff. nice having a vacuum forming machine. pkj
#17 |
on a 69 - 72 I think there may be about 4 or 5 inches there
#18 |
![]() Join Date: Aug 2004
Sounds like a good item to sell on the board if you have access to a vacuum forming machine. That would be a nice upgrade, especially for us in the hot zone. Anything to get cooler air in the intake is a good thing.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
