Old 01-01-2007, 02:23 PM   #1
ol Curt
Junior Member
ol Curt's Avatar
Drum Brake Question
For one of you guys out there that still has drum brakes and has put a set on recently, I have to ask if you found any tips or tricks that made it easier to get all the confounding springs back on? This truck has the self adjusters and I think four springs (not counting those for hold downs and such). I have been fiddling with one wheel for several hours!!
ol Curt is offline   Reply With Quote
Old 01-01-2007, 03:02 PM   #2
kwkenuf
Retrofit Management
kwkenuf's Avatar
Re: Drum Brake Question
A brake spring tool helps but is not necessary. I did my rears a couple of months ago, the first one took a while, the second went easier. I've got a couple of pics if you're interested. I've seen much better pics on this board though with new parts instead of old brake dust covered shots.
My retrofit fleet
-1966 Suburban 2002 Tahoe drivetrain, firewall, floor, chassis and interior in progress
-1965 C-10 shortbed stepside, 2003 5.3/4L60E conversion. Power steering, tilt wheel, power front disc brakes, 2.5/4 inch drop, relocated fuel tank and battery, 2002 Silverado buckets and console. Swap Pics
-1968 Camaro 95 LT1/4L60E lots o' mods Web Page
-1961 Corvette project Corvette Corrections frame, C-4 suspension and brakes, 02 LS1/T-56, Never ending body workPics
kwkenuf is offline   Reply With Quote
Old 01-01-2007, 03:42 PM   #3
ol Curt
Junior Member
ol Curt's Avatar
Yes,
please send or post pics.
Old 01-01-2007, 03:54 PM   #4
Woogeroo
Drum brake assembly
Assembly sequence for a "typical" GM drum brake
1966 GM half-ton pickup (Delco Shown, Bendix similar)
http://www.pbase.com/nufsed/drumbrake
That is showing part by part on the rear brakes, the main difference is the park brake lever.
pics of the front and rear drum brakes on my '65 c10 :
http://matraca.home.mindspring.com/i.../05302006.html
Another trick is to jack the other side of the truck up and pull the wheel and drum off and see how it is routed.
good luck,
-W
Woogeroo is offline   Reply With Quote
Old 01-01-2007, 04:00 PM   #5
ol Curt
Junior Member
ol Curt's Avatar
Wow,
That's neat having the parts painted and such. It makes it easy to identify them. I have the other wheel off. It's making the springs all fit without it coming apart that is giving me fits. I just finished a big bowl of chili ( I do everything better on a full stomach) and looking at the service manual. I have an idea it is the sequence of things that makes a difference. Made a copy of the page and am back out tot he garage to try again. Thanks for the help. Wish me luck!
Old 01-01-2007, 06:39 PM   #6
SkylineNXS
SkylineNXS's Avatar
I had fun a few months ago rebuilding one side of my brakes. Like u said, it s teh sequence. You can get spring puller tools and such but i did it with my dad. I took some time, but so does a lot of things. Two people definantly makes it easier.
Brad
2000 GMC Sierra EXT Cab Short 4x4, finally mine...
1966 C10 SWB Fleet, 250 I6, three on the tree....
Previously Owned....
1987 Chevy R10 "Silverado" (at least the badges were) Short Step 350 700r4....
1972 Chevy LWB Fleet 350/350
EXTENDED CAB ALL THE WAY!
.._..~...-...._...____
.._..-...______|_|__\____
..-..~.|_(O)__|_|__|_(O)]
SkylineNXS is offline   Reply With Quote
Old 01-01-2007, 06:53 PM   #7
Fred T
Cantankerous Geezer
Fred T's Avatar
A good set of brake spring pliers is a big help. And there is a huge difference between the made in USA and the made in xxx pliers.
http://www.lislecorp.com/tool_detail.cfm?detail=19
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 01-01-2007, 07:00 PM   #8
layinrocker65
layinrocker65's Avatar
I have taken my brakes apart afew times and I just do one side at a time and look at the other side if I get suck. Used brake tools for the springs and that helped the most. Thats all I have to say
layinrocker65 is offline   Reply With Quote
Old 01-01-2007, 08:09 PM   #9
ol Curt
Junior Member
ol Curt's Avatar
Thanks guys. I finally got the one side on, and the pics were a great help. I think the brake pliers would be a good addition. I'm looking into those.
Woog, as always, your links are top notch!
Bob
Old 01-01-2007, 08:21 PM   #10
ol Curt
Junior Member
ol Curt's Avatar
Fred!!
Just when I was starting to buy some parts for the truck, and you had to send that great link to Lisle Tools. Now I'll be spending some money on tools.
Old 01-01-2007, 08:27 PM   #11
Woogeroo
The spring holder tools are a must, they make things so much easier.
ol Curt - glad they were a help, I needed those painted pics when I reinstalled the ebrake system on my '65, they saved my bacon.
-W
Old 01-01-2007, 08:44 PM   #12
zenish
i also use vise grips,i use them to grab the end of the spring so i hook it.
1964 c10 short step
1962 econoline van
1989 rs camaro
2006 yamaha vino 125
1975 goldwing
zenish is offline   Reply With Quote
Old 01-01-2007, 09:23 PM   #13
poorboy
poorboy's Avatar
You can't go wrong spending $$ on tools. It's nice to have the right tool for the job. It also makes it alot easier.
poorboy is offline   Reply With Quote
Old 01-04-2007, 03:15 PM   #14
marvxyz1
marvxyz1's Avatar
Use a good pair of vice grips and a little bit of muscle. You can also use cvice grips to install the anchor springs, by openiong the grips about 3 eigth in. an holding the spring down and turning the pin from behind the backing plate.
marvxyz1 is offline   Reply With Quote
Old 01-04-2007, 03:40 PM   #15
SIR
SIR
SIR's Avatar
....investing in a GOOD pair of SAFTY GLASSES is one of the first tools you should purchase...those springs will come at you FAST!....
66long low fleet http://community.webshots.com/user/LVNR66
SIR is offline   Reply With Quote
Old 01-04-2007, 05:24 PM   #16
slepysal
slepysal's Avatar
A dust mask iis a good idea too.
slepysal is offline   Reply With Quote
Old 01-05-2007, 02:02 AM   #17
leftcoast66
leftcoast66's Avatar
Sometimes when even the spring tools are hard to get the springs on I'll try and pop the smaller springs into their position I use a flat screwdriver. It was an amazing help last week doin the brakes on my '66
leftcoast66 is offline   Reply With Quote
