01-01-2007, 09:36 PM | #1 |
Having issues
Solo hard top removal, any ideas?
What ideas have you guys used to get your hard top off and on without killing yourself?
I have a big tree I could park under, and use a comealong to winch the top off, but the donor blazer dudn't run to park under it I got the white top off by lifting the top, shoving 2x4's underneath it, strapping the rear together, and lifting from the inside, moving it over. I would use the same procedure for this scenario, but there is a height difference. I cant let the air out of thetires, seating the beads is a joke, and using jackstands is questionable on soft dirt, even with support from a 4x12. Last edited by masterbeavis; 01-01-2007 at 09:38 PM. |
01-01-2007, 10:07 PM | #2 |
THE VILLIAGE IDIOT
Re: Solo hard top removal, any ideas?
well what i used to do when i put a shell on my 3/4 for the winter,,nd remove it for the summer..i built a stand out of scrap 2xs then one person can remove it and install it...i made it level with the bed,,and just got under it to slide it on and off,,thenn i used the clamps to hold it down in case of the wind...i know its different,,but it should work the same for your application...
honestly honey,,i have no idea how that truck got here. |
