The Best Member
Okay I just recently bought a 70 shortbed and want to put some exhaust. On my 72 l/b I ran 40 series flows and 2 3/4 pipe in an H pattern out the back. For my 70 I want to run 3 inch pipe w/ 40's out the back. My question is should I run an X pattern or an H????
70 shortbed C10 -------SOLD------- 1972 Chevy C-10 l/b |
Broken Down
Re: Exhaust Questions
I have always liked the X seems kinda easier to me to rout the tubes around trans ect.
kenm78 1982 Chevy 4X4 Project truck ![]() ![]() ![]() ![]() “It’s better to keep your mouth shut and let people wonder about your ignorance, than open your mouth and reveal all doubt” |
![]() Join Date: Jul 2006
The H pipe will help balance the exhaust while the X will balance and scavenge. In a typical street application either is fine. IMHO
In a high HP app I'd go with the X for sure. |
#4 | |
The Hammer Man
![]() Join Date: Oct 2006
what is the best pipe material to go with?
Boise69. Bought in Boise ID and its a '69 ___________________________________________ 1969 Chevy C-10 SWB 350/400 - drivable project www.americanhammer.com 2013 MBZ Sprinter customized 2005 MBZ Sprinter Van 2004 Land Rover Discovery 2001 Yamaha Road Star 1997 MBZ E420 1989 Ferrari Mondial T |
Parts and more parts
Discussion that I had with Flowmaster, many years ago; hope this will help you.
FIRST: Are you running a Big Block motor? If not, then the 3" exhaust will hurt your performance more than it will help it--Especially if you want to run duals. The size of pipes will hamper the breakdown of exhaust gases and create a reversionary backpressure that will hamper proper exhaust performance. As exhaust gases cool, they create a vacuum effect, which causes the exhaust to assist in pulling the the warm gasses out of the engine. The bigger pipes causes the vacuum effedt to dissapate early and the gases then create a backpressure for the engine to push against. In other words, the smaller pipes 2 1/2" will give a more optimum flow and make more horsepower than the 3" pipes. Second: The X pattern will scavenge exhaust more efficiently than the H pipe pattern. The H design is a definite torque builder and creates a more balnced flow on a motor than a set of two independent pipes. I would recomend the X pipe design. |
![]() Join Date: Mar 2003
Go with a single 3''. Personally, I got away from duals. Lot cleaner under the truck and a single 3 will be more than enough.
#7 | |
The Engine Whisperer
I had been looking at 3" exhaust and there is defintiely a breaking point on the pipe size. There are motors that can extract HP out of 3", but you are right, they have to be serious in the build to do it.
i have a 2 1/2 going into a 3 in with flowmasters and no X or H pipe am i losing HP?
(Only) Member of the CPNE Fan Club ![]() ![]() 67 C-10 350 with 3-speed tranny and 308 gears swb step ![]() 82 Z28 Camaro 355 small block over 350 hp and a borg warner super t-10 (blown engine) 72 Chevy K20 Suburban (future project) 70 Chevy K20 now 68 GMC K2500 2003 Chevy 2500hd ccsb 4X4 (daily driver) |
The Best Member
I have a 350 with a 3 speed on the tree... So 2 1/2 is the best way to go? What should I expect to pay for this setup. Back home in Cali I payed over $500 for new pipe, 40 series exhaust, and chrome tips... I got a little ripped off IMO. Im in Alabama now and I talked to a muffler guy right outside of the post and he said $400 for my new setup. What yall think?
The LuvShack Garage
Ted, everytime something like this comes UP I post this, it is right out of
the Flowmaster Dealers book, it help alot of people out, too small of pipe can hurt performance, but what alot of people don't know that too big is an issue also, not enough back pressure can cause issues also, I worked 2.5 yrs. on the side at a local Muffler and Brake shop, X-PIPE is the way to go IF you have the room, if not a H-pipe will work just as well also ![]() *PS - I have it in High Res also, luv2xclr8@charter.net (Subject 67-72)
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Tow Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
The Hammer Man
Very neat, thanks for that! so 2.5 is the way to go for my duals. Right now i have neither an X or an H, they are sperates and they run straight back and out the rear. The pipes are not that old, I have a receipt from the PO who had them put in 2004. But they rusted through in 3 different places and the mufflers too, the system is called flowtech. I have their sticker in my window, that will be scraped off soon.
So, are there better pipes to go with or are all pipes made from the same type of steel? sorry for this Hijack!!
#13 | |
The LuvShack Garage
![]() 2. Aluminized (Will rust eventually, takes alot longer) 3. Stainless Steel (Will rust after you are buried) ![]()
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Tow Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T Last edited by LUV2XCLR8; 01-02-2007 at 07:37 PM. |
#14 | |
The Hammer Man
Since i'm replacing all of this i'm going to replace the headers too, so far i'm leaning towards the elite headmans
#15 | |
The LuvShack Garage
#16 | |
The Hammer Man
I did a poll back in Nov regarding Magna or Flows and Flows won. As long as you think the quality is there and i can get it all in one place then the 600.00 seems to be a bargain to me.
#17 |
The Hammer Man
Chevrolet C10/20 Cat-Back Exhaust System
Click Image To Enlarge PRICE: $642.56 PART #: 16643 YEAR: 72-76 DESCRIPTION: Dual Exhaust System V-8, Dual Exhaust, Tru-X (rear coil spring), 2.5" SS tubing. SOUND CLIP: No Sound Clips available DYNO SHEET: No Dyno Sheets Available INSTALLATION: Install Sheet MAGAZINE ARTICLES: No Articles available CHECK INVENTORY: Check Availability Thats what i found, does that seem like the right set-up?
#18 |
Can't ReMember
Eleven years ago I had the local custom exhaust guy redo my whole exhaust sytem with duel stainless. Everything on my truck is slowly rotting away. That exhaust system still looks like new.
Looking at the HP on that chart it shows 350 = 250 HP. I thought that these stock motors were only about 170 HP.
Adversity doesn't test your character; it reveals it. 71 C-10 LWB 350/TH350. I purchased it in 1978 for $1400. I'm currently abusing it daily. (when it's running ![]() |
#19 |
The Best Member
haha no problem man... I knew I wasnt the only one that had some questions! ![]()
#20 | |
The Hammer Man
what have you decided on doing so far?
#21 | |
The LuvShack Garage
![]() Ted, I think that's it, I can confirm the part # for ya Thursday, and BTW, I have flows, Magnaflows that is ![]()
#22 | |
The Best Member
