01-02-2007, 11:48 AM | #1 |
Hood Alignment
What Is It To Do To Get The Rear Of The Hood Down When Adjusting It ?? Thanks,buddy
01-02-2007, 02:02 PM | #2 | |
Re: Hood Alignment
I'm not sure of the question? Is the rear of the hood not laying down all the way when you close it?
2003 GMC Sierra 1500 WT 1995 Nissan Hardbody 2016 Hyundai Veloster Turbo DC2 (SW/AW) Clyde W. Harvey USN "Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill |
01-02-2007, 02:16 PM | #3 |
Re: Hood Alignment
He probably has the same problem as me. When the hood is shut, the rear of the hood is too high, mine is a good 1/2 to 3/4 inches higher than the fender line in the very back.
68 Chevy 383/350 w/shift kit, 380hp/425ft-lbs, 4.5/5 drop, 17" TT2s 64 Cadillac Sedan DeVille |
01-02-2007, 02:19 PM | #4 |
Re: Hood Alignment
I had that issue on mine, I just kept playing with the mounting of the hinge on the fender until it seated. If I am not mistaken I had to "tip" the hinge down towards the front to get it to sit down correctly. Now if only all the panels were squared up maybe the gaps wouldn't be so bad!
-Chris Building a stripper, one part at a time: 1969 K5, 307, 3spd, 3 seats, hard top. Added Pwr Discs, Pwr Steering, Aux Battery, T-case Skid, Lighted Sidemarkers, HEI, Lock-Right Diff, ECE Class IV Hitch, 32" MT/Rs. Parts to Install: Hand Throttle, Console, Tow Hooks, Dual Horns, AM-FM, Dealer Swing-Away Tire Carrier, Gas Tank Skid. Also building a 1950 Willys CJ-3A and off-roading a 2001 Nissan Frontier on 1-Ton Portals... |
01-02-2007, 02:39 PM | #5 |
Re: Hood Alignment
Check this thread
http://67-72chevytrucks.com/vboard/s...hood+alignment
Good Judgment comes from experience. Most experience comes from bad judgment. |
01-02-2007, 02:43 PM | #6 |
Re: Hood Alignment
Agree with cduster.
I tried this procedure on mine and it worked perfectly. You need two people to get it done. I think Huck posted this originally: Before you go buying new hinges etc. do this simple adjustment-----then let us know how well it works. REAR HOOD HEIGHT ADJUSTMENT ---by Huck! 1- Loosen the 6 (3 on each side) hinge to fender bolts (9/16ths socket). 2- With the hood open---push it up further till you feel some resistance like it is as far as it should go with no extra stress. 3- Now with the 6 bolts just a little snug---push the front of the hood up a bit more to pre-load the springs---and with it held up like this---/---tighten the six hinge bolts. 4- BEFORE CLOSING THE HOOD, CAREFULLY CHECK FOR ALIGNMENT OF THE HOOD TO THE FIREWALL COWL--THIS SOMETIMES CASUES A BIND SO CHECK IT OUT FIRST. 5- Assuming the hood is now coming down in the rear like you want, adjust the hood front to rear using the 4 bolts (2 on each side) that mount the hood to the hinges 'IF NECESSARY'. 6- You may need to tweek the hood hinge adjustment a bit but in just about every case I've seen, this adjustment process fixes the problem without having to buy new hinges. If the hinges are worn real bad, then you will need new ones but----just make sure the old ones are well lubricated at there multiple pivot points and you may be home free!!!! Let us know---Huck |
01-03-2007, 08:28 AM | #7 |
Re: Hood Alignment
Thanks To All,thats What I Needed To Know.later,buddy
