01-02-2007, 01:25 PM | #1 |
steering stabilizers
I just got done(well,in the process of) installing a 6" lift on my swb 4x4.It has a steering stabilizer on it now but I am going to replace it.Any suggestions on what kind I should get?The truck will be a D.D./part time offroaded,not a heavy wheeler and will probably have 35's on it if that matters.
01-02-2007, 04:06 PM | #2 |
Post Whore
Re: steering stabilizers
I have Rancho's single shock stabilizer kit on my 69 K20. It seems to do the trick. I believe they offer two different shocks, I got the better of the two on mine.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
01-03-2007, 04:47 AM | #3 |
I use ranchos
01-03-2007, 09:46 AM | #4 |
The Blazer King
I have a duel Procomp. The one where the are on top of each other.
72 2wd Blazer. Its the superbichinest, megacoolinest, superflowinest. |
01-04-2007, 09:11 PM | #5 |
Chevys Kick A$$
I think I got a procomp one or one of similar quality and it works good. Its only a single though.
*HOODS is what I answer too* -'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold -'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit -'86 K5 Blazer Silverado 6.2 4" lift 35"s -'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's -'83 Monte Carlo T-Tops. 126,500 Original Miles -LATER I would rather push a Chevy then drive a ford!!
01-04-2007, 09:29 PM | #6 |
69k10stepside, At what point should a guy go to extra stabilizers? I have an axle with a dual setup but is it needed? I think they are rugged trail. It also has the original stock stabilizer....
01-04-2007, 09:54 PM | #7 |
Sofa King. We, Todd, Ed.
I too would like to know the pros/cons & peoples opinions of single vs. dual stabilizers.
~John 71 Blazer One Ton 65 Chevelle Station Wagon x2 59 Belair 2 Door 71 Chevy Open Road Van RV www.myspace.com/johnnywagon |
01-05-2007, 12:19 AM | #8 |
Msgross,I dont think dual stabilizers would be needed unless you moved up to a big lift (6"+),big tires,and do alot of heavy wheeling and still use it on the road.I use a single one on the 69 w/ a 6" lift though.You running 33's and no lift really dont need dual stabilizers IMO but its your truck and is up to you.Someone else might have more to say about them and when you need duals....
01-05-2007, 04:33 AM | #9 |
years ago I had read that when you go to 35's you may have a need for duals. Going to two of them will test your gearbox. Something to think about.
01-05-2007, 09:42 AM | #10 |
69k10step, interested in purchasing a dual stabilizer setup? I'm gonna post it on the for sale thread soon... i can send a pic, it's an end to end system, not stacked.
01-05-2007, 09:56 AM | #11 |
The Blazer King
I also heard that 35's and up is where you should consider a dual setup. No need for smaller tires. They do make a difference as my 38's were all over the place without crossover and she tracks pretty straight now.
01-05-2007, 08:06 PM | #12 |
K5Camper
I've got 35's with just a single skyjacker stabilizer. No problem here.
Rob Z. 1975 K5 350/465/205/D44/12b 4" lift on 35's- RIP 1991 K5 8.1L/NV4500/241/D44/14b FWC Camper |
