I'm a poor spectator
I got bored so here are pics of my blazer
I was trying to put some new ones up but I couldn't find the cable for my camera so here are some old ones. I used to thing mine was in pretty bad shape but i've been told by Critter that mine is practically show quality (compared to his of course).
![]() ![]() ![]() ![]() I do have to admit though, I do have a dam solid tailgate ( i'll get better pics later) ![]() I like to call this one: Unfinished business ![]() Like I said, i'll get some better ones later. By the was, does anyone else have that style wheel, I can't recall if anyone does or not.
2006 Jeep Unlimited IMPACT ORANGE 1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig ![]() 1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!! ![]() 1979 Ford F150 4x4 SWB Built Ford Tough!!! ![]() 1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!! |
Post Whore
![]() Join Date: Feb 2000
Re: I got bored so here are pics of my blazer
That's a good looking K5. Lots of potential too!
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
Future TOTM Winner
You definitely have some good sheet metal. However, that big empty area under the hood is really slowing you down! When is it going to be drivable? Let me know when you need some help.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces) 72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts 2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver Check it out www.lsdyno.com |
That thing is practically show material when compared to mine too. But, I can fire mine up and move it!
These TX trucks do keep some parts of the tubs and etc in good shape. Mine lived in and around El Paso, TX for 31 years before it moved to Corpus. My tailgate is cherry as well. Too bad the winshield frame is shot. How is yours? I keep hearing that the hot-weather states have issues with shrinking the seals and when water gets in it's all over. That happened to mine anyway.
-Chris Building a stripper, one part at a time: 1969 K5, 307, 3spd, 3 seats, hard top. Added Pwr Discs, Pwr Steering, Aux Battery, T-case Skid, Lighted Sidemarkers, HEI, Lock-Right Diff, ECE Class IV Hitch, 32" MT/Rs. Parts to Install: Hand Throttle, Console, Tow Hooks, Dual Horns, AM-FM, Dealer Swing-Away Tire Carrier, Gas Tank Skid. Also building a 1950 Willys CJ-3A and off-roading a 2001 Nissan Frontier on 1-Ton Portals... |
The LuvShack Garage
I've seen and owned a whole lot worse, not a bad start
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Big Piggy: "Goliath" 07 Kodiak C4500 Lil Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
There is one thing that bothers me on mine and that is the drivers side door. It rained a couple days ago and this morning I opened the door and I heard water sloshing around inside it. I ain't no expert but that can't be a good thing. Oh and my windshield frame is solid.
Future TOTM Winner
You probably just need some new window felt around the glass. It sounds like water is running down the outside of the glass and collecting inside the door. Not too big of a problem.
Blazerless
My 70' Jimmy used to fill the doors when it rained too. I'm a cheap SOB so I just drilled some drain holes.
72' K5 Blazer 4x4 350TBI/700R4/NP205 3/4 ton diffs. Daily driver. SOLD ![]() 69' Beaumont 388/700R4 11.70@116 ![]() 77' Bronco, Wife's mall cruiser/poser 4x4. Capable but too pretty to go offroad. |
I actually cranked mine up and took it around the block. The battery was dead and I need to change the oil and put in an air filter but other than that, it seemed to run ok.
'72 K5 CST Blazer 4x4 in perpetual progress '96 2dr Tahoe 4x4 daily driver, Black Bear Performance tune, 285-75-16 Nitto Grapplers, Magnaflow muffler, K&N Air filter, Bilstein Shocks.........E-fan, DT Tri Y or Pacesetter LTs coming soon Last edited by Blizz; 01-02-2007 at 10:30 PM. |
Okay here are some new ones
This has me bothered. Critter says that the PO must have covered up the hole where the ashtry went but it looks so good that I'm convinced it must have been like that from the factory. I know the crack is there but why would anyone cover that up??????? ![]() This is a reciever hitch that the PO also put on there. It's just some homemade thingamajigger, it'll be coming off soon if anybody wants it. ![]() Well one more thing the PO did wrong. This is some sort of sunroof. Yeah, it pretty much sucks. ![]() Apparently this Blazer has had more than it's fair share of mirrors ![]() ![]() I guess this is supposed to be a problem area on these trucks since the battery sits right over top it but mine is pretty darn solid. ![]() One last one of my MSD box location. I like that fact that it's hard to see from the outside. ![]() Is a tach a rare option, my sticker says it came with one but it's gone (more shadows of the PO).
2006 Jeep Unlimited IMPACT ORANGE 1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig ![]() 1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!! ![]() 1979 Ford F150 4x4 SWB Built Ford Tough!!! ![]() 1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!! Last edited by Jtrux; 01-02-2007 at 10:54 PM. |
The LuvShack Garage
Señor Member
And you probably need to clean out the crud in the bottom of the door. There are drain holes in the thing so water shouldn't be standing long enough to slosh.
#13 |
Señor Member
I'm with Critter. Look at the lines I highlighted below. Those don't look like what the factory would have done had they decided to leave off the ashtray. I'll be a quick look under the dash will resolve any question as to whether the ashtray was removed.
#14 |
![]() Join Date: Feb 2004
That is one nice place to start
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!" |
#15 | |
Future TOTM Winner
#16 |
KEEP ON TRUCKIN'
![]() Join Date: Jun 2005
Aint nothing wrong with that Blazer. There are alot of trucks on your street.
JIM '97 GMC Sierra K1500 '95 Chevy Silverado C1500 '71 Cheyenne Z71 / LT1 & 4-Speed SWB K/10 ![]() http://www.youtube.com/watch?v=4l689JKXPnA http://67-72chevytrucks.com/vboard/payments.php "LIVIN' FREE FOREVER" ![]() |
#17 |
Future TOTM Winner
It's a great feeling isn't it! I keep looking for you on the road, but not yet...
#18 |
Global warming is a myth
He's from Texas. That's the way we roll.
Later, Buddy
Henderson, NV 1972 K5 - Lifelong project - Needs Time, Place, Help & Parts!! 1990 K5 with 37's 2003 Discovery SE7 - Wife's |
#19 |
KEEP ON TRUCKIN'
I should have noticed that!
#20 |
Yeah it really is. I haven't gone too far in it. I need the bumpers and all the lights/signals put on and working before I take it too far. I just can't wait to get it street worthy so that I can cruise around in the spring and summer with the top off. That has to be a great feeling I can't wait! We're gonna have to get together and take em wheeling or just for a cuise out to Canyon Lake and BBQ this summer.
'72 K5 CST Blazer 4x4 in perpetual progress '96 2dr Tahoe 4x4 daily driver, Black Bear Performance tune, 285-75-16 Nitto Grapplers, Magnaflow muffler, K&N Air filter, Bilstein Shocks.........E-fan, DT Tri Y or Pacesetter LTs coming soon |
#21 |
That's a mighty fine idea. If i'm not mistaken Critter's girlfriend has a boat and if we're nice maybe we can borrow it for a day...or two.
#22 |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Nice looking ride I have those wheels on my blazer.....
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
#23 | |
Future TOTM Winner
#24 |
![]() Join Date: Oct 2006
Hey just to answer your ealrier question, yes the tack was a fairly rare option. They made their way into a lot of the bigger trucks, my dad has two old straight trucks with tacks. They aren't impossible to find if you wanted to replace one, I saw a nice looking complete dash w/ tack at a swap meet this summer for $225, but I think that was a deal. It was gone by the time I got back to it, or I would have an extra.
