Love that '69
Lowered Truck Problems
I was wondering if anyone else has had the same problem with their lowered trucks. My '69 C10 is lowered 2" Front & 3" Rear with drop coil springs. I have 1.50" wheel adapters on the rear axle to push the rear tires (235/75/R16 all around) out away from the inner fender. The problem I have is that occasionally (on pot holes, bumps in road, etc.) it feels like the shocks are bottoming out. I replaced my shocks a year ago, front & rear, with new ones. Do I maybe need some type of drop shocks for lowered trucks? Any help would be appreciated.
I AM CANADIAN & PROUD OF IT!!! ![]() 1969 Chevy C10, SBC V8, TH-350 Transmission, Metallic Blue, B&M Megashifter, GT Grant Steering Wheel, 2.25" True Dual Magnaflow Exhaust System w/ SS Magnaflow Embossed Tips, 700W Rockford Fosgate Stereo System, Lowered 1" Front & Stock Rear, 4.56 Rear with Positraction, 15" Chrome Rims w/ Chevy Center Caps & Michelin Tires, 4.5" K&N Air Filter, Edelbrock 'Elite' Engine Accessories, Chrome Powdercoated Engine Parts 2001 Cavalier Z24, 2.4L DOHC, Silver, Spoiler, AEM Intake, 2.25" Magnaflow Exhaust System, Clear Euro Tails, Tinted Windows, 400W Clarion Stereo System |
Truck Enthusiast
Re: Lowered Truck Problems
do you feel it hitting in the rear more? check to see if the axle is hitting the bump stops. i'd start with that, if thats the case, put a low profile stop in or just remove them
'85 swb |
Outlandish Trends - FL
Hmm, 3" in rear you shouldn't need to trim your bumpstop. How much space do you have between the axle and the bumpstop at static height?
-Bret 67 short-fleet sold! |
i have 5" drop spring in the back and 275/60r15 tires with no spacer without any tire rub
on the front i have a 2.5 dropped spindle with one coil cut on the stock spring with 245/60r15 tires i have no problems of tire rubbing or bottoming out |
Love that '69
From what I noticed last year before I parked my truck for the winter, the rear end seemed ok, it was hitting more in the front. Like I said, it seemed like the travel on the shocks was reduced significantly. Maybe it's just me... I don't know.
with your truck sitting at ride height with weight on the wheels measure(ruler) the distance from a-arm to bump stop then measure distance of exposed rod on shock absorber if it isnt greater than the bump stop +measurment you need different shocks and or mounts
67-72 Addict!
Can you post a pic showing what your truck looks like at that height?. Thanks
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
The LuvShack Garage
Another thought, do you have a rear shock relocater kit? it helps
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Big Piggy: "Goliath" 07 Kodiak C4500 Lil Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
#9 | |
Seņor Member
Also, the wheel spacers are a red herring.
#10 | |
he could mount less wide tires so to sidewhalls tug in from the rim , that might solve it too
i got a job again and having fun at it too idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts |
heres a pic of mine
i have 8" chrome rallys from wheel vintiques i think the rear still could come down another 1-2 inches |
