Old 01-02-2007, 09:13 PM   #1
heavychevy72
clutch question
ok, i got a 72 lwb 4x4 with a 12 inch lift,running 42's my question is i've installed a 454 with a granny 4 speed with 488 gears,but i've got a little squealing noise,i think it might be pilot bearing,i replaced it, but it came from auto zone and i have got some bad parts from there before but could it be my clutch aint adjusted just right, i'm use to a hydrolic clutch any help would be gratefull, because i'm ready to tear it apart again,for the forth time
heavychevy72 is offline   Reply With Quote
Old 01-02-2007, 09:25 PM   #2
truckdude239
truckdude239's Avatar
Re: clutch question
what kinda off clucth are u running? got to something like a center force clucth and release bearing something that will handle the power
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 01-02-2007, 09:27 PM   #3
truckdude239
Re: clutch question
http://store.summitracing.com/partde...5&autoview=sku
David fuller
2000 Tahoe 5.3l 378
Old 01-03-2007, 07:35 PM   #4
heavychevy72
Re: clutch question
yeah got a high dollar clutch,bought from jegs proformance,but it makes the noise (i forgot to say before) until i just let my foot rest on the clutch pedel,not applying much pressure at all,some tell me the clutch aint adjusted right,then others pilot bearing,then others throw out bearing i guess just tear it apart,and put more new ones in???????
Old 01-03-2007, 08:38 PM   #5
Jtrux
I'm a poor spectator
Jtrux's Avatar
Re: clutch question
It's easy to adjust them. You want to be able to press the pedal in about 1.5 inches before the clutch engages (actually it will be disengaging). A good way to tell it's not adjusted correctly is that the pedal won't come out all the way and will stay "stuck" in the depressed position unless you pull it up with your hands. I've never heard any noises from my clutches so I couldn't tell you what that would be but if resting your foot on the clutch alleviates the problem then your throwout bearing would be a great place to start. I have run centerforce throwout bearing on two of my trucks (1977 ford f100 with 351Windsor) and my Blazer with no problems.
You didn't say if you had any body lift on that thing, if you do that might play a part in correst adjustment of your clutch since the linkage would have to be modified for the lift.
2006 Jeep Unlimited IMPACT ORANGE
1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig
1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!!
1979 Ford F150 4x4 SWB Built Ford Tough!!!
1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!!
Jtrux is offline   Reply With Quote
Old 01-05-2007, 08:06 PM   #6
heavychevy72
Re: clutch question
no body lift,just springs,i greased the Z-bar today ,where the ball goes in the block i don't think that will help but i really DON'T look ford to pulling all that back out ,i may just run it (big mud bog in georgia)in march,maybe it will either quit or break,i thank ya'll for the help and will try to return the help
Old 01-05-2007, 10:46 PM   #7
1969K10
1969K10's Avatar
Re: clutch question
if I was going to guess, I'd say its your throw out bearing since you mentioned that it goes away if you rest your foot on the pedal...
Good luck with it!
1969 K10 - V8, 465, 205, 12 bolt, D44 2002-current
1969 K20 - V8, 465, 221, Eaton, D44 2012-current
Nothin' but drums on all 4 corners!
past horses in the stable
72 C10-short step (97-02), 68 C10-long fleet (06-12)
1969K10 is offline   Reply With Quote
Old 01-05-2007, 11:27 PM   #8
454_72_4X4
454_72_4X4's Avatar
Re: clutch question
Throw out bearing is your problem.
What kind of linkage system are you using for the clutch?
Don't waste your money on a diaphram type clutch, (including Centerforce). Diaphram pressure plates won't last in a truck because of the heat.
Get a good Borg & Beck style 12 in clutch. I have a Ram in mine.
72 C20 4X4 454 4 speed
89 Trans Am (was) 305 TPI 700r4
93 C1500 2wd Extended cab 350 700r4
98 Sonoma (TPI outa the Trans Am)
03 Yamaha 660 Raptor
03/04 660 Raptor
07 700 Raptor
85 Honda Odyssey
454_72_4X4 is offline   Reply With Quote
