Old 08-22-2002, 08:13 PM   #1
brad69C-10
Question how much fluid does a 350TH hold?
The converter had a quart in it, when I put it in, but now how much does the rest of it hold? It is a fresh rebuild with a stock pan......Thanks
69 C-10 Pro Street...........red on black...........big block and a lot of go fast stuff under the hood
Still in progress ...........
brad69C-10 is offline   Reply With Quote
Old 08-22-2002, 08:34 PM   #2
Low67C10
A th350 holds 11qts. total.
No, Its not a 454
Low67C10 is offline   Reply With Quote
Old 08-22-2002, 08:53 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
They hold just enough to soak you, every tool you own, and about 3/4 of the pavement in your driveway.
11 qts sounds right. I would start off with 9 or so, then slowly add more with it running and warmed up.
Old 08-22-2002, 09:23 PM   #4
oldyeller
Captain CAAAVVVMMMAAANNN!
oldyeller's Avatar
be sure to cycle it through the gears to insure all the "pipe spaces" are filled with fluid and air burped out, could make a little differance in capacity..
72 LWB Fleetside C10 Custom 350/350
97 GMC Yukon 4X4 SLT
Anna, Texas
check out the project old yeller
oldyeller is offline   Reply With Quote
Old 08-22-2002, 09:32 PM   #5
brad69C-10
longhornmail, you are sooooooooooo right....I still can't get this %$#@% stuff outta my hair.........lol...........tools will never rust though.......;0
Old 08-22-2002, 10:22 PM   #6
Longhorn Man
LOL! I know, i serviced 3 trannys today at work. I washed my hair 3 times, still dirty.
