Old 01-03-2007, 03:53 PM   #1
DangerBoy
Another PCV question
Yesterday I replaced the old dried out PCV and breather grommets on my 350. Now when I drive it there is a whistle comming from the PCV side. Before I replaced them it was blowing alot of oil out of both sides but the new grommets have fixed that. Could my PCV valve be stuck? If not should I be worried about it? Thanks.
2002 S10 ZR2 for the dirt.
1968 C10 shorty for the street.
She said the truck would be the end of us. I still have the truck!
DangerBoy is offline   Reply With Quote
Old 01-03-2007, 04:59 PM   #2
bryanw1968
bryanw1968's Avatar
Re: Another PCV question
Sounds like something is not completely sealed up. It may be a vacuum leak you're hearing. How's your idle? You can spray some carb cleaner around the area you're working on and see if the idle changes to find the leak.
Good luck.
bryanw1968 is offline   Reply With Quote
Old 01-03-2007, 05:08 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I'd start with a new valve, they are cheap even by my standards
